Projector HID Wiring Harrness Problem.
Hey, first off i would like to say i used to be a member of fourm a long time ago. my name used to be vonzipper1152 for any of you old school cats out there. ill include a pic of my car.
here's my problem:
I just ordered some new headlights cause my old ones were leaking, so i ordered another set of projectors this time tho i ordered them with an HID kit. the problem is, is that the wiring harness that they came with only has one (9007) connector, and only one light will come on. so am i just screwed, or is there an easy fix to this? i will include a pic of the wiring harness layout for you guys so maybe that can help. also these headlights are the DEPO projectors, and does anyone else have these?
Thanks For Your Time,
Andrew
here's my problem:
Andrew
i am confused by your question... the hid kit will plug into the sockets inside the projector housing itself... my only guess is that you ordered a 9007hid kit? the bulb inside the projector should be h7 i believe if you could give a better explanation of what you're asking that'd be good
Just wanted to see if you ever got your kit straightened out. I ordered the projectors from RRM and got the same instructions. I seem to be having an issue with the high/low beam configuration though. When I turn on the headlights, all the bulbs light up. I'm guessing that just the projectors would be the low beam. When I hit the high beams, the projectors cut off and only the inner bulb is illuminated. I'm not sure, but I think thats a little backwards... any help would be greatly appreciated.
From what I have heard the model I have (M14-1102O-AS1) might possibly be european spec wiring so that sucks.. ha. relays? wiring issue? anyone?
