Question on replacing brake light bulbs
Old Apr 23, 2010 | 11:36 AM
Christoforo's Avatar
My left rear brake light is out and I can't seem to figure out how to replace the bulbs, I removed the two phillips screws that are visible when you open the trunk but the light is still held in place by something I can't seem to locate.
I searched and couldn't really find anything helpful.
Old Apr 23, 2010 | 11:44 AM
rrd's Avatar
rrd
if you pull the lining of your trunk forward right the behind where the tail light goes, you can see over by the pointed end there's two plastic things that keep it pulled in, i think if i remember correctly you can push them out from the inside, but be careful they break easily
Old Apr 23, 2010 | 11:49 AM
Just got it, thanks. The filament is burned out so its just a replacement bulb, does anyone happen to know the bulb number by any chance?
Old Apr 23, 2010 | 01:13 PM
Alright went to pep boys and found the right bulbs, $5 and 5 minutes in the driveway and I'm back in business. Thanks guys.
