Idling high after extended highway run
Old May 3, 2010 | 02:30 PM
CdnFF's Avatar
Hi gang,
So over the past year my '06 Ralliart has begun to idle high when I get stuck in stop and go traffic after been driving on highway for an hour or two. It will start at 1500 and steadily start idling higher and higher, getting as high as 3000 rpm. I'm thinking might be heat related, as when it has happened was in the mid-high 20s C (75-80 F). Of note, the only change I've done to my car is I added a K&N Filter. Any advice would be greatly appreciated.
Cheers,
Al.
Old May 3, 2010 | 04:11 PM
ralliartist11's Avatar
This same thing happens to me every once and a while. I have always wondered what causes it. I always put my foot behind the accelerator and pull it back towards me and that usually solves the issue. I think it has somethin to do with the accelerator's spring not pushing back far enough.
Old May 3, 2010 | 04:19 PM
Jabl3s's Avatar
Also maybe a possible accelerator pedal sensor failure? That is what happened to me except it wouldn't rev at all.. idk if the pedal sensor works both ways. Just a guess.
Old May 3, 2010 | 04:26 PM
NJRalliart's Avatar
lucky you, when i am on the highway for too long my cars idle goes down lmao
Old May 3, 2010 | 04:31 PM
fugiwara's Avatar
could it be sticky pedal like toyota?
Old May 3, 2010 | 06:25 PM
Myszkewicz's Avatar
First thing I would check is the cable going to the accelerator position sensor. Make sure it has a little slack in it.
Of course, if it were me I'd also be hooking up my laptop and datalogging it when the issue arose next time. I'd want to see if it showed the throttle at 0% or not, and would also check the reading for target idle.
Old Sep 8, 2010 | 12:51 PM
Ralliartize It's Avatar
Did you ever get this fixed. This definitely mechanical, as when you put your foot behind the gas pedal and flip it up the idle drops back to normal.
Old Sep 9, 2010 | 06:01 PM
NJRalliart's Avatar
lucky you , after i drive on the high way for a while and then get back in to my town my car idles low and my oil light flashes lol yay:]
Old Sep 10, 2010 | 03:10 AM
Sounds like you oil sensor is dying.
Old Sep 10, 2010 | 10:39 AM
NJRalliart's Avatar
It sounds like your right lol yeah I know it is but my oil is full and I don't feel like fixing that lol waste of money
Old Sep 10, 2010 | 11:13 AM
Oil sensor is dirt cheap, under 10 bux. Installing it is no fun though.
Old Sep 10, 2010 | 09:46 PM
NJRalliart's Avatar
exactly, waste of my time. The time it takes me to install that i could have drove to rutgers and found myself a skank hahahah ;]
