Problems w/ Headunit after MINI BATTERY!
Old May 12, 2010 | 01:31 AM
car852's Avatar
Ever since I installed my mini battery, my headunit hasn't been able to read SD cards, USB drives, or even CDs for that matter. I just use auxilary for now.
Any one else have that problem?
Or have any ideas on how to fix the problem?
Old May 12, 2010 | 04:57 AM
Thomar's Avatar
maybe ur head unit it pooched. did u ground it properly?
Old May 12, 2010 | 07:00 AM
otter's Avatar
EvoM Administrator
Seems like this would be a question for the headunit manufacturer.
Old May 13, 2010 | 01:01 AM
car852's Avatar
Hmm. did i ground it properly? That's a good question. It stays on when I shut off the car. I have to manually shut it off.
Old May 13, 2010 | 01:14 AM
Myszkewicz's Avatar
That doesn't sound like a proper install. That could be what led to the unit being pooched.
By itself, there's no way changing the car battery would cause this.
Old May 13, 2010 | 11:17 AM
car852's Avatar
I didn't think so, but it only started happening after the battery install. I've had the headunit like this for the life of the car. I installed it correctly to the harness. I'm not new to automotive electrical. Buut for some reason it doesn't seem right. It is a cheap headunit, but I know that would have nothing to do with it staying on after the car is off. Hmm. I'll go in there and double check and clean everything out.
I talked to the manufacturer they said to check all the wires and then disconnect the battery for a whole 40 minutes to do a reset. lol thats quite a while. but i'll do that sometime this week.
Old May 13, 2010 | 03:31 PM
Ralliartize It's Avatar
Your radio relay is dead.
Old May 13, 2010 | 06:37 PM
car852's Avatar
how do you know that my radio relay is dead?
Old May 13, 2010 | 08:16 PM
GearDownSon's Avatar
Sounds like you have a problem with your switch/constant power wire.
Old May 13, 2010 | 11:27 PM
Beardly P's Avatar
Hail to the Beard
What is the advantage of a "mini" battery?
Old May 14, 2010 | 12:44 AM
Buxnbaas's Avatar
They're cute and little and all the girls say "awww, what a cute little battery" and then you get their phone number, hook up for a date, maybe get you some booty......
Or it could be the lightweight thing...
Anyone else got an answer??
Old May 14, 2010 | 02:08 AM
I would actually LOVE one.
With the turbo kit in there its really tight an a lot of pipes are not as free as i would like em to be. Other than that......nothing cept weight that i know of..
Old May 14, 2010 | 04:15 AM
My roommate had the same issue with his radio...relay dead.
Old May 14, 2010 | 01:39 PM
car852's Avatar
for me it was price and weight.
Old May 14, 2010 | 10:07 PM
Beardly P's Avatar
Hail to the Beard
That's cute. I remember my first beer.
