Keyless Entry Question
Old Dec 18, 2010 | 01:00 PM
slc-ralliart's Avatar
So my keyless entry is acting funny. When I hit unlock it will unlock my drivers door like it should, but two clicks won't unlock the rest of the doors. I can unlock all the doors from inside with the lock switch. Also the key fob lock button works fine and will lock everything properly. Any reason why the double click unlock of all doors isn't working? Both my fobs are doing the same thing so I know they are not the problem. Any input or ideas appreciated.
Old Dec 19, 2010 | 08:03 AM
deathsythe99's Avatar
id take it back and tell them to fix it.
Old Dec 19, 2010 | 09:29 AM
Beardly P's Avatar
Hail to the Beard
There are many reasons why this is happening. The main one is probably because it hates you.
Not really. Taking it back to the dealer to fix will be pricey, but probably is something the dealer should take a look at. Sometimes my key-less entry doesn't work too.
Old Dec 20, 2010 | 06:45 PM
Does anyone know how to take off the door panel? I think my problem lies in the door itself.
Old Dec 20, 2010 | 07:48 PM
Christoforo's Avatar
I've had this very same issue, except it has worsened into now not even working at all. I have to lock/unlock my doors with the key now (and I've gotten used to it).
I believe its an issue with the driver's side automatic door lock seizing, if that lock doesn't go first then the rest won't go at all.
Old Dec 20, 2010 | 08:25 PM
Beardly P's Avatar
Hail to the Beard
I have to open my doors with the key too, no big deal. Although I did have my car worked on about a year and a half ago when someone backed into it. I had the door replaced, and every now and then won't open with key-less.
Old Dec 21, 2010 | 07:23 AM
Yeah buy mine won't even unlock all the doors with the key in the drivers door. It unlocks the drivers door only and sounds like it is probably siezed. Hopefully it will work itself loose. I assume the faulty part is in my drivers door. I am sure the dealer will rape me if I take it in so I guess I'll live with it in the meantime.
Old Dec 22, 2010 | 09:18 AM
Beardly P's Avatar
Hail to the Beard
Yea they will for sure
Old Dec 22, 2010 | 09:27 AM
Antonovich's Avatar
There's screws in the door handle and around the door edge. Just unscrew the visible screws, take out the door handle cup and pop the door off.
