Windshield Washer Fluid
Old Feb 26, 2011 | 05:47 PM
Beardly P's Avatar
Hail to the Beard
So I looked into taking out the tank, and when directly underneath it, I see one bolt but I cannot determine if there is another (perhaps on the side or what not). For those of you who have taken the tank out, can anyone confirm that there is or is not just one bolt to take off?
Also, there was a little pink sponge in the washer fluid tank as well. I took this out (as it smelled rotten). Not sure if this was the cause, but was wondering if anyone else has this in your tank.
Old Feb 26, 2011 | 06:04 PM
lanzerralliart's Avatar
EvoM Super Moderator
I am seeing 3 bolts here's a pic...
Old Feb 26, 2011 | 08:09 PM
Beardly P's Avatar
Hail to the Beard
Did you have to take off your bumper to remove?
Old Feb 27, 2011 | 04:02 AM
I didn't take the bumper off but I don't have the oem bumper either , nor do I have any of the splash guards on the bottom front end.
Old Feb 27, 2011 | 10:01 AM
Beardly P's Avatar
Hail to the Beard
I see. There is not much room to work with in order to take the tank off, and I'm not about to start taking my bumper off.
Old Feb 27, 2011 | 10:35 AM
otter's Avatar
EvoM Administrator
The pink sponge thing is just there to let you know when the tank is full.
It's also really, really easy to take the bumper off if you end up needing to. I have to imagine that you should be able to drop the tank through the bottom without pulling the bumper, though.
Old Feb 27, 2011 | 10:40 AM
lloyd03oz's Avatar
i have the same problem except mine smells like the actual fluid cleaner and what not, i use rain-x.
Old Feb 27, 2011 | 12:53 PM
Raikiri's Avatar
yeah taking off the bumper is really quick like under 5 minutes. shouldn't be too hard but then again i have zipties and little twisty-ties holding my bumper on so that probably would do it lol
rain-x fluid is all i ever use unless i take it to a shop and they fill it up w/ whatever crap they have...
Old Feb 27, 2011 | 05:04 PM
xmaster19's Avatar
Can't you only take the splash guard off to do this?
Old Feb 27, 2011 | 05:22 PM
I'd think so, I really doubt removing the bumper is needed to remove it, I think 2-3 of the splash guards would set you up with plenty of room...
Old Feb 28, 2011 | 06:16 AM
Beardly P's Avatar
Hail to the Beard
I do not want to do this either.
Old Feb 28, 2011 | 06:37 AM
Beardly P's Avatar
Hail to the Beard
I am just going to flush it out with water and soap or something.
Old Feb 28, 2011 | 07:39 AM
otter's Avatar
EvoM Administrator
Don't use soap in there, it'll likely gum up the pump.
Old Feb 28, 2011 | 10:22 AM
Beardly P's Avatar
Hail to the Beard
Awesome. Should I just use water and keep flushing?
Old Feb 28, 2011 | 10:32 AM
otter's Avatar
EvoM Administrator
White vinegar. It'll kill anything that's growing and also deodorize.
