Cluster and marker lights
Old May 20, 2011 | 10:43 PM
aznchin07's Avatar
hey guys,
not sure if anyone knows how to fix this but, i might as well ask
not sure if this could be with the problem as well, but i had my master and slave clutch cylinders change on Monday(slave) and Wednesday (master), also i add a switch for my LED light i have for my driver/passenger/doors.
After i changed fixed putting the switch in, my instrument(backlight for tach and speedo) lights and right side marker lights all stopped working.
i have traced all the wires from the center console to the fuse box and everything is good, all the fuse are good.
i anyone can give me ideas that would be great.
Old May 22, 2011 | 10:50 PM
Myszkewicz's Avatar
Where did you tap into power for your LED lights? Also, check the fuses in the relay/fuse box under the hood. That's where your cluster and signal lights get their power.
If your right side marker doesn't work, check your right taillight. They're on the same circuit. If the taillight is good, the bulb in the side marker is probably burned out. If they're both out, check the fuse.
