Future plans for the RA
Old Dec 27, 2012 | 12:17 AM
CrAnSwIcK's Avatar
stock 4G63 for an Evo 9 makes like 290hp even for a FWD car it won't be too much...an LSD might be in order though... but a little bit of tuning, maybe a bump in boost and you could easily and safely make 290whp which gives you a power:weight of 1:10 which would be awesome that's my goal.
Old Dec 27, 2012 | 07:44 AM
2006_RA's Avatar
Originally Posted by soulesswarrior
Last I heard was belhousing mods were needed to bolt the 63 to our tranny, plus there's always the unique factor.
https://www.evolutionm.net/forums/04...aped-evo8.html
Old Jan 13, 2013 | 01:17 PM
soulesswarrior's Avatar
Anyone have a quick answer for this before i start ordering parts? Curious as to the clutch, will i need to mix clutch components or will the RA clutch be fine?
Old Jan 13, 2013 | 01:37 PM
CrAnSwIcK's Avatar
you're using an RA flywheel on a 4G63 bottom end?
Old Jan 13, 2013 | 04:25 PM
i would most likely be using the evo flywheel, im just pretty much useless when it comes to clutches lol
Old Jan 14, 2013 | 07:16 AM
2006_RA's Avatar
From input shaft diameter and spline count the 4G63 flywheel seems incompatible with the RA gearbox.
This is based on specs I have come across on sites like rockauto and some other sites selling parts.
I have not had the privilege of touching one.
Old Jan 14, 2013 | 07:41 AM
kaoscage's Avatar
Before I got my evo and put the RA on hold, I had started to draft a head swap from a 9 to the g69 block. Seemed to me to be a lot cheaper and easier than the engine swap. Just my .02.
Old Jan 14, 2013 | 07:53 AM
2006_RA's Avatar
I'm not certain that it's easier, cheaper maybe, just less than worthwhile given the nature of the 2 bottom ends.
Where the 4G63 starts performance the 4G69 ends. You dont just want to say you've done it, you want it to be reliable and durable too.
I see compatible 4G63 engines from $2000 closer to $3000 is the norm, with wiring harness, ECU and engine accessories.
How much less would it be only getting the parts for the head swap ?
Old Jan 14, 2013 | 01:03 PM
CrAnSwIcK's Avatar
i'm with george, if you're going through all that trouble, your best bet is a full engine swap... unless you build the 4g69 block, but after rods and pistons, plus rings bearings and seals, you're probably getting close to the price of a decent mileage 63 anyways...a modestly built 4g69 won't handle much more than a stock 63...
Old Jan 14, 2013 | 02:04 PM
Then with this information do we know if the 69 flywheel bolts to a 63 block? Has anyone compared the flywheels?
Old Jan 14, 2013 | 06:25 PM
CrAnSwIcK's Avatar
they're both a 7-bolt crankshaft, should bolt right up...though i can't speak of spacing for certain, but it should be the same as a 69
Old Jan 14, 2013 | 06:44 PM
yeah from browsing through the swap thread that was linked here the guy said he used a RA flywheel and clutch. so looks like thats the route i will take. i figure within 3-4 months ill have a motor setting in the garage awaiting install.
Old Jan 15, 2013 | 09:25 PM
SSP-Ralliart's Avatar
would be interesting to see a solid running 4g63 in a ralliart. Im sorry to hear about your car man. That sucks bad. If you get a 4g63 running solid in the ralliart we should go to the track and race sometime.
Old Jan 21, 2013 | 03:34 PM
AdamRA's Avatar
Originally Posted by OttRalliart05
My future plans are to sell the lass. She has run her course time to let go...
My feelings exactly. My car is going up for sale end of this week.
Old Jan 22, 2013 | 10:54 AM
Tw3NTy0n3's Avatar
Such a sad sight seeing your RA sitting there and then me going in and ripping away her intake.
Hopefully she's back sooner than later!
