First Post: Master Clutch Cyl Replacement
Old Apr 18, 2015 | 09:40 PM
apamburn's Avatar
Hey everyone,
I have been lurking and studying the how to found here:
https://www.evolutionm.net/forums/04-06-ralliart-how-s-installations/665085-how-replace-clutch-master-cylinder.html
But finally decided to introduce myself and ask a question. I drive an 06 RA - bought it at 86k miles and now up to 110. It has served me wonderfully. My first Mitsubishi - but it will definitely not be my last. I don't think I will ever leave the Lancer.
My clutch stopped working and turned out to be the MCC. I have removed it, but I am having difficulty with the 17mm Banjo Bolt as described in the link above.
It has a hole drilled clean through it to allow fluid to flow through from the MCC to the Slave Cylinder, however, no matter how I screw it on, the holes do not align with the hole in the clutch line hose fitting.
It sure seems that this is something that should be aligned. Right?
It is a PAIN to get the MCC back in place! Any suggestions on the job?
Thanks everyone in advance.
Old Apr 20, 2015 | 04:31 PM
CrAnSwIcK's Avatar
it doesn't matter, it's banjo fitting...the "banjo" has a channel inside to allow flow...orientation of the hole in the bolt is irrelevant...
should have got the 2.0L lancer/Evo master cylinder....much easier to remove/install, and less likely to fail...it doesn't have that stupid plate on the side...that o-ring fails, and you're SOL. what I do is tie twine or fine rope to the piston arm, and run that through the firewall, then up and back out the driver side door, then I can tug on the rope with one hand while wiggling the master cylinder into place with the other...but the Evo CMC is smaller, and far easier to install...
Old Apr 20, 2015 | 08:03 PM
apamburn's Avatar
Thanks for the info. If I ever replace it again I'll look at the evo mcc.
I eventually did get this one in and reconnected. All better now.
Old Apr 24, 2015 | 07:31 AM
CrAnSwIcK's Avatar
did you make the correct adjustment? very important...
Old Apr 24, 2015 | 08:05 AM
apamburn's Avatar
Do you mean adjusting the clutch pedal? Its serviceable but not quite perfect. I'm going to look at it this weekend. Any suggestions?
Old Apr 25, 2015 | 06:59 AM
CrAnSwIcK's Avatar
adjust to manufacturer specification and you shouldn't have any problems...if you need the procedure, PM me...
two things you don't want, and are both the result of an improperly adjusted clutch pedal are; clutch not fully disengaging, resulting in excessive clutch wear, as well as excessive synchronizer wear, and clutch being disengaged too much, resulting in excessive wear on the release bearing and possible damage to the pressure plate diaphragm...
Old Apr 27, 2015 | 12:37 PM
apamburn's Avatar
Message sent. Thanks for the offer to help!
arximus
Apr 4, 2015 12:48 PM
arximus
Feb 7, 2015 10:29 PM
nickyboost
Mar 24, 2014 09:07 PM
