O4 ralliart shop manual
Old Nov 16, 2016 | 03:45 PM
elkmonster04's Avatar
Help!
Can someone please direct me to a link or somewhere I can get a real shop manual, doing a clutch o the ralliart, and looking for torque specs and such..
Thx,
Old Nov 18, 2016 | 12:43 PM
the1ftw's Avatar
I don't know if you found your answer yet but this is what I used. Hope this helps...
http://mmc-manuals.ru/manuals/grandi...004500-21B.pdf
If you plan on removing your flywheel you will might encounter the 10 point bolt and will need this socket.
https://www.amazon.com/CTA-Tools-375.../dp/B00DOQ0494
Old Nov 18, 2016 | 10:42 PM
CrAnSwIcK's Avatar
the flywheel bolts are hex head...if you remove the 10 point bolts the flywheel is junk, as it will no longer be balanced...
