Gas for the RA?
Old Apr 29, 2004 | 12:29 PM
chuethao's Avatar
Talking Gas for the RA?
i was just woundering what type of gas are you guys putting in your RA's i put in 93 but my cuz told me to put in 91 octane but i though the higher the gas the better it is for them right?
Old Apr 29, 2004 | 12:44 PM
Deltarider99's Avatar
It doesn't necessarily mean better. It all has to do with what the engine was designed to use, and at what rate the gasoline burns. In some cases, putting a higher octane gas into an engine that doesn't need it may actually hurt the motor in the long run. The Mitsu manual says the car was designed for use with 87 octane gas.
But me? I always put in 89. Had a bad experience with some crappy 87 octane once, and I'm not sure I'll ever be able to get over it. You should stop wasting your cash on high octane, though. It gives no performance gains, except for mental ones.
Old Apr 29, 2004 | 01:25 PM
ciaxtrinity1's Avatar
^right on. I stick to 87 & keep the extra change
Old Apr 29, 2004 | 02:37 PM
LDB's Avatar
LDB
Absolutely, positively WRONG. Lots of people somehow have the idea that more is better but that's not the case. Octane reduces/prevents detonation and ping. It does this by making it harder to ignite the mixture. That makes it ignite later. That's for higher compression engines that need the time and resistance to get to full compression before firing.
The RA engine is made to run on 87 octane.
Will higher octane help a stock engine? NO
Will higher octane hurt a stock engine? MAYBE YES
DON'T RUN OCTANE HIGHER THAN THE ENGINE IS DESIGNED FOR UNLESS YOU'VE MODDED IT WAY UP.
Old Apr 29, 2004 | 05:44 PM
Hellacious's Avatar
Call me crazy, but how do you know the octane numbers and stuff? It says regular unleaded only, and there's only one regular unleaded pump at the gas station....?
Old Apr 29, 2004 | 07:12 PM
Kelmar's Avatar
As far as the whole octane thing goes, I've read plenty that say that it's bad for your car, and I've read plenty that say it's good for your car. I take it all with a grain of salt. Personally, I run 93 in my OZ and have had no problems. As a matter of fact, I get better gas mileage with 93 than I did with 87. After crunching numbers, it is cheaper fo rme to put 93 in my tank than to put 87 in (I have not tried 89, so I don't know the numbers for it).
At most gas stations, there is a little yellow sticker that says what the octane is. At the gas station I go to there are two pumps per spot (if that's the right word for it). One for diesel, another for 87, 91, and 93 octanes.
Old May 2, 2004 | 07:38 PM
Hellacious's Avatar
yea i got it now, i just never paid attention to the octane. its always just regular unlead. nothing else should be put into a lancer (unless its turbo or whatever)
Old May 3, 2004 | 05:57 AM
raelic's Avatar
read my post at the bottom of the thread in the link for all questions on octane etc....use whats in the manual!
https://www.evolutionm.net/forums/sh...781#post917781
lilmac789
Lancer Engine Tech
10
Oct 26, 2010 10:53 AM
garditox
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Jul 30, 2010 02:21 AM
04WhiteRalliart
Oct 11, 2006 05:28 AM
ralliart 04 21
Oct 5, 2006 08:45 AM
moore0226
Northeast Region
21
Sep 23, 2005 12:45 AM
