Headlights Unit Question ! ! !
Old Jul 11, 2004 | 09:43 PM
jeddi's Avatar
OK I know this is stupid but this is what happened at first, I got new bulbs. I was trying to find a way to change it out. I wasn't looking hard enough to notice you twist and so forth. Instead, I unscrewed one side of the headlight and noticed I couldn't take it out......!!!
Fustrated as I was and hot as hell, I started looking around. FINALLY! I noticed you had to twist the cap off and pull the bulb out. Well after doing so, later that night I noticed the left side was now higher than the other side.
What do I need to do to even both sides up? Any suggestions or what you would do normally to adjust it?
I appreciate this very much for any info. Thanks.
Old Jul 11, 2004 | 10:08 PM
pocoRA's Avatar
Go to the dealership.
Old Jul 12, 2004 | 10:10 PM
RalliartJP's Avatar
The actual headlight assembly or the lighting? There should be a knob for the lighting, I think?
Old Jul 12, 2004 | 10:25 PM
jeddi's Avatar
the assembly
Old Jul 13, 2004 | 07:08 PM
xstephenx's Avatar
Just bring the whole car in and ask them to adjust the headlights. Tell them you just noticed them. It should only take them a min or two.
