Service engine light???
Old Aug 6, 2004 | 02:54 PM
Mitsuracer27's Avatar
Question Service engine light???
Can anyone help me, changed my factory low/high beams today to SilverStars. Looks better, but what a b**** to put it. On the passenger side I had to remove the wiring harness to the throttle body sensor to squeeze my hand in there, now my service engine light is on.....will this go away on it's own or am I going to have to go to the dealer to get it reset. If I go to the dealer will they reset it under warranty? Someone told me once the computer recognizes that nothings wrong it will shut off on it's own...but I don't trust this induvidual. (Did not start the car while harness was off).....HELP....
'04 Diamond White Pearl Ralliart
Ractive Pedals
SilverStar bulbs
RRM SRI
Coming Soon:
RRM lower sway bar
RRM lower tie bar
17" Racing Sparco NS-II Python with 215/40HR tires
Old Aug 6, 2004 | 03:26 PM
otter's Avatar
EvoM Administrator
I remember someone else on the board doing a headlight bulb install and having the *exact* same problem (had to DC the throttle sensor, too). All ya gotta do is disconnect your battery for 5-10 minutes or so to reset your ECU and you should be good. Check your manual about letting your ECU "relearn".
Old Aug 6, 2004 | 04:25 PM
WoRkZ's Avatar
Yep... that's me screwing my ECU up. I didn't have to wait 10 mins. though... I plugged the battery back on after 10 sec. and everything was okay, altough the engine sometimes chokes when I first start it in the morning. Strange side effect...
Old Aug 6, 2004 | 04:27 PM
WoRkZ's Avatar
What did you mean about the learning part tough??!?
Old Aug 6, 2004 | 08:07 PM
Myszkewicz's Avatar
The "learning" is your ECU setting fuel trims and stuff. When you reset, it goes back to a default setting, which will get the engine running, but not running at its best. It takes a while to get everything back to normal after an ECU reset. If it doesn't go away after a few days of driving the car, then you might have other problems.
Old Aug 7, 2004 | 08:31 AM
otter's Avatar
EvoM Administrator
All RAs have that "choking" during cold starts, it's odd. When they start, run kinda rough at around 1200rpm, stutters, then miraculously smooths out at a nice 700 or so rpm.
Old Aug 7, 2004 | 09:42 AM
ralliart86's Avatar
just the engine warming up and the oil moving around most likely
Old Aug 7, 2004 | 12:34 PM
redralli04's Avatar
Strange i had to disconnect the plug too to get my headlights in however i never had any problems with the service enigne light
Old Aug 7, 2004 | 01:11 PM
Fifty's Avatar
Same here disconnected the plug, put my Silverstars in, reconnected the plug and all was well.
This might seem like a stupid question, but did you push the plug back all the way in?
Old Aug 7, 2004 | 01:53 PM
Freddie1111's Avatar
I unplugged it too w/ no problem. The last person who had a problem with this restarted their car first, then realizes he had forgotten to plug it back in and had to resett the ECU.
Old Aug 7, 2004 | 07:43 PM
WoRkZ's Avatar
Post
Well... I didn't really start the engine, I just turned the key to the on position. But as one might say, it's all the same to the ECU... It read a sensor fault anyway.
Old Aug 7, 2004 | 09:22 PM
That must be it, I didn't start my car but I did turn to accessory to make sure that the new bulbs worked before I pluged the sensor harness in....I took my car to a local goodyear dealer and they hooked it up to there computer and shut the engine light off for me, since I get my oil changes and stuff there. FYI...according to the onwners manual you should never disconnect the battery unless necessary to change out....I guess resetting the ECU in the "learn" mode isn't alway's reliable...might have future problems if it doesn't reset to factory specs...that's what my local dealer told me on the phone also.
