Fog Lamps
Old Aug 13, 2004 | 11:08 AM
ViperKilla's Avatar
Question Fog Lamps
Did anyone else notice that their fog lights will only come on when the headlight switch is turned to full on (not just the running lights)? Is this the same with everyone elses? I would rather when driving in fog , not have the headlights on and be able to turn just the fog lamps on. I know here in Ontario anyways we have daytime running lights but they are dimmer than turning on the actual headlamps by the switch.
Old Aug 13, 2004 | 03:33 PM
ralliartpr's Avatar
All late Mitsus do that.I check the fog light switch in my Galant and it has a little circuit board in it so I think it wiil be a little difficult to modify.
Old Aug 13, 2004 | 06:48 PM
SlowRyd's Avatar
Yep, its the same way on mine.
Old Aug 13, 2004 | 06:50 PM
JDM_FeTiSh's Avatar
From: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
it's the same on any mitsubishi cars
Old Aug 13, 2004 | 07:54 PM
BLKRalliArt04's Avatar
Its also the law, you cannot have ONLY your foglights on without your headlights being on at the same time. at least thats how it is here in va
Old Aug 14, 2004 | 05:28 PM
SlowRyd's Avatar
i wish it was that way in SC, I'm sick and tired of A**holes, driving around with just fogs at night. it throws of my depth perception and makes it harder to judge distances to oncoming traffic.
Old Aug 18, 2004 | 12:52 AM
raliart's Avatar
bmws have the ability to have driving lights on with only parking lamps and no headlights on, thats stock ****, so i dont see a problem it is only illegal to drive with foglights, a fog light is yellow, a driving light is white, we have "driving" lights according to DOT regulations i have been told by several police officers
Old Aug 18, 2004 | 08:35 AM
Myszkewicz's Avatar
In WI, at least, driving lights alone are fine. The law states that after dusk, you must have at least 2, but no more than 4, forward-facing white lights.
I'm trying to find if the law says anything about yellow fog lights...
Old Aug 18, 2004 | 11:06 AM
WoRkZ's Avatar
Post
If the circuit board you mentioned is anywhere else than built into the switch, I don't see a problem in rewiring the switch so that it bypasses the circuit. You probably would have to find the power leads and lights wires and link them directly to the switch... If any of you guys attempts this, let me know and I'll be able to help you out. Just post some pics so I can make sense of the circuit board and various wires around it...
BTW: If the mod cannot be done by rewiring the existing circuit, just run 12v DC current (adding a fuse, of course!) from your fuse box to the switch and then to the driving lights and your good to go. Of course, only one lead needs to go to the switch, not both of them! If anyone is interested, I may take the time to put a schematics up...
WARNING: Both these methods may render the dashboard indicator inoperable (not that big a deal though)... depending on the way the dashboard LED is inserted into the circuit.
_
Old Aug 18, 2004 | 11:10 AM
Myszkewicz's Avatar
I was just thinking about jumping a wire from the parking lights to the relay for the driving lights, so whenever I turn on the parking lights the DLs come on, too.
Old Aug 18, 2004 | 11:19 AM
WoRkZ's Avatar
Thumbs up
Good idea! I might just try that myself! This sounds like the most practical way of doing it...
