Hesitation in 1st???
Old Sep 22, 2004 | 01:22 PM
Freddie1111's Avatar
Lately, sometimes when I pull away from a stop in 1st gear slowly (revs b/w 1k and 2k) the car hesitates and the motor feels like its going to stall. If I 'm more agressive and keep the revs over 2 it doesn't do it. This is new and has never happened before - now it does it more and more often. Anyone else having this problem? Any ideas what it might be? I was thinking maybe the CAI was restricting airflow at low RPM but that doesn't make too much sense. It feels like a fuel starvation problem so I'm worried the fuel pump might be on its way out - I don't know.
BTW - I've been driving stick my whole life (14 years driving) so its not my driving technique etc. This is a new problem on my car - 4200 miles so far. It has happened w/ many tanks of gas - all from reputable name brand stations - so that's not it either.
Old Sep 22, 2004 | 02:04 PM
otter's Avatar
EvoM Administrator
Put your airbox back on (or leave the CAI if your dealership is cool w/it) and take it in as a warrenty fix
Old Sep 22, 2004 | 02:08 PM
My dealer's cool. I just don't have time right now to bring it in so I'm curious what it is. Also, I want to be sure I don't eff something up by driving it too much. You're right though - I take advantage of my warranty! I'll see if I can bring it in on Saturday or something.
Old Sep 22, 2004 | 04:41 PM
Squashzilla's Avatar
I've had the same problem for a while. It started about that same time for me. Generally, it only occurs when the car is cold. I read on another post that it was a quick fix at the dealer. I think describing the problem will be the hardest part. I'm like you...I just need the time to take it in. I have 9 years manual driving experience so I know it's the car and not me.
Old Sep 23, 2004 | 08:49 AM
illuminati's Avatar
perfect someone else having this problem i thought i couldnt drive for a second i just started experience this
Old Sep 23, 2004 | 08:57 AM
stwelve's Avatar
hey.. i have the same prolem, it is the cold, its getting colder now and the turbo needs a little more time to warm up otherwise you will feel that lag in first and secound when you take off
Old Sep 23, 2004 | 10:23 AM
Thunder-rush's Avatar
I have CAI and 12K. My car does the same thing from 1000 to 2000rpms. Its like a bogging condition. Another thing I'm getting is a lot of "ratteling" in the exhaust system. The stainless steel flex pipe mesh is always making noise and sounds like a 10 year-old car. I might put a clamp around the flexpipe to see if it stops.
Anyone have the same..?
Old Sep 23, 2004 | 11:02 AM
RalliartJP's Avatar
Stwelve- You got a turbo in your Ralliart? I wish I had went to your dealership????
Old Sep 23, 2004 | 11:12 AM
psy-q's Avatar
cold turbo
Old Sep 23, 2004 | 11:17 AM
Thunder, has your car been doing it a while? It can be pretty violent when it bogs sometime w/ this condition. Could it be possible if you've been having this problem for a while it has loosened up the exhaust/flex pipe? I'm bringing mine in as soon as I can so other problems don't start comming up.
Old Oct 2, 2004 | 07:51 AM
ciclon1's Avatar
Hey guys you are not alloned I have the same problem and it realy don't matter if is cool or hot .
It happen generly went I'am on a trafic light setting for a few only at the time, it won't do it if I get to a Stop sing and I stop and go, Like you guys said I know is the car and not me I have 21 years driving stick and that is all we had were I'am from LOL never had the chanse to drive auto to I move to the States , I haven't had the chanse to take it to the dealer for that matter and it started happenig to me after I hit 2500 miles I currebtly have 4200 and the car is 5 week old .LOL
Old Oct 2, 2004 | 10:23 AM
turbonutter's Avatar
Question for some of the more technical guys: Since I don't own one (YET!) does the RA have a MAP sensor or a MAS sensor? If all it has is a MAP sensor, it could be that the ecu needs to "re-learn" it's curves with the CAI in place - this happens on my car. Once I reset the ecu by disconnecting the battery for a couple minutes, the bogging problem goes away. If it does indeed have a MAS sensor, (which I think it does) this might not solve the problem. It's still worth a shot though I think.
Old Oct 2, 2004 | 10:37 AM
Myszkewicz's Avatar
It has a MAS sensor.
If he just put on the CAI, the ECU might need some time to relearn. However, he said it's been happening for some time, at least several tanks of gas.
I'm kinda curious to see what his dealer says.
Old Oct 2, 2004 | 03:30 PM
ciclon1's Avatar
My car is doing it and is STOCK STOCK STOCK nothing other then me .
Old Oct 2, 2004 | 03:51 PM
SlowRyd's Avatar
I have the same problem, always when the engine is cold. but it can be a pretty violent shake, hell i thought the tranny was going to drop out the other night.
