Ground Control Sleeved Coil Installation!
Old May 2, 2012 | 03:59 PM
kapitolralliart's Avatar
LOLOL...I didn't really pay much attention to where you lived. Anyway, the drop looks sweet to me. I really will consider the GC's if the springs I found brand new for dirt cheap don't come thru. Thanks for the pic though.
Old May 2, 2012 | 04:43 PM
keithislegit's Avatar
Oh my god. That's the perfect height. I want I want!
Old May 2, 2012 | 04:49 PM
stockley1234's Avatar
No problem. Once aligned I should be good to keep it that height, I hope. I'll post up some more photos once it warms up a bit and I can comfortably get out.
Thanks for the compliments too, I like the way it sits as well. Any lower is just too much around here.
Old May 2, 2012 | 05:14 PM
todd6027's Avatar
Originally Posted by stockley1234
It's not a McPherson setup where everything connects to the strut; ours are independent from basically everything else other then the knuckle.
stockley1234
id double check and have a rethink on that
Old May 2, 2012 | 07:53 PM
Hey stockley, did you just get new tires or new wheels and tires? If wheels, what specs?
Old May 3, 2012 | 03:47 AM
I just tires. General Exclaim UHP I got them for a pretty good deal through work so whatever. lol.
I was planning on doing rims this year but I don't think I am yet. I just dropped $1000 on a new camera lens so I dunno
Old May 3, 2012 | 06:41 AM
How was the ride at that height?
Old May 3, 2012 | 07:42 AM
It's not that bad actually. A little rough but bearable.
Old May 6, 2012 | 06:17 AM
roblaza's Avatar
Any rubbing?
Old May 6, 2012 | 04:37 PM
Also, are you using a camber kit?
Old May 7, 2012 | 04:01 AM
Originally Posted by roblaza
Any rubbing?
Rubs at 75% lock going forward and roughly 60% in reverse. It only seems to be rubbing on a push in clip in the fender liner so I am thinking it can be fixed fairly easily.
No camber kit yet. The car is raised back up now till I get one because I don't want to ruin my new tires too much.
Old May 7, 2012 | 07:12 AM
Those are your stock struts right? I wonder how they will hold up once you have the drop on them.
Old May 7, 2012 | 07:46 AM
I can almost gaurauntee that they won't last. A drop like that will demolish those stock shocks. I am already looking at getting new ones, GR-2's more then likely, so I am not to worried.
Old May 7, 2012 | 08:24 AM
I'm probably just going to save up for some bc racing coilovers. Lol.
Old Dec 22, 2013 | 10:39 PM
ctitan9@aol.com's Avatar
Hey stockley,I'm lowering my 03 Lancer and I've lowered it successfully except when ever I turn the front two sleeves and springs spin which causes a weird spring popping noise, any ideas of what's going on?
