will this work
will this work
dont know if this has been asked before, but i couln't find any posts about it
will i have any problems running
Motegi DP-10 18" x 8" (will they rub????)
with 215/35R18 yokohama parada spec-2 tire
the offset is + 40
on 2006 RA
sorry if this been asked before
the offset is + 40
on 2006 RA
i had a set of 18 x 8 i wanted to put on my ra and they where rubbin bigtime . i tryed test fitting one of them without the tire on and the rim itself was actually touchin so i dont know, i geuss it all depends on the offset.
Bhodi??? This is ukr_oleg...I think it's u
If so, I though the rims you got where 18X7.5? If they are 18x8 i think you will have to roll the fenders to fit those bad boys. Good luck...And if u're Bhodi I'll see you @ the meet on friday.
so they had some 215/35R18 availible....
so we decited to go to 18" thinking that DP-10 were availible in 18 x7...which now i know they are not...we got the 18 x 8...
and the 18" DP-10 are also 23.5lbs...which is 5lbs per rim heavinr thne the 17 x7 at 18.5lbs...
in any case im not geting what i originally wanted...
low cost/medium weight rim with decent tire
Motegi DP-10 18" are 218.00/each CAN...so unless someone can recomend me a better wheel that is around the same cost and close to the same look...(trying to match the EVO 9 look with Enkei rim)
hey, did you try www.wheelguyz.com yet , they have some crazy package deals right now. thats where i got my 17s from, wheels tires and lugs , mounted and balanced shipped to my door for $700.00
Registered User
From: Yokosuka Japan (Lancer currently in Hawaii with wife)
I have a quick question... I know it's probably in another thread, I kinda looked but being military and mostly getting on the computer at work I don't have time to check everything... I know 18x8 definately won't fit, but does anyone have any pics of their ride with 17's or 18's? I am a fan of that "full rim" look, you know where the rim takes up a good bit of the wheel well... Either that or a link to a good thread that does...
YAY...it will work
Just got back from fitting the 18 x 8 with a 215/35R18 tire...fits perfect...no rubbing at full turns left and right...looks extremly nice...will post pictures after i put them all on ....thats whenever it actually gets warmer in Canada here...so i can actually run them without having an accident
but it will only work with +40 offset...so dont try other offsets
Registered User
Yeah, once the sun comes out you can see how that 35R handles better... No rubbing at all? You didn't roll the fenders? That's nice, cuz I was looking at 18's myself... I wonder if a 18x7.5 would be a bit better though, didn't think an 18x8 would work, but guess you proved that wrong...
Registered User
Yeah that's where I'm worried... Cuz I found a pair of 18's that I REALLY want, but they don't come in 17's... If I have to roll the fenders a bit, maybe, but I don't want to have to roll them to much...
nah it wasnt the fenders it was touchin, it was the control arm, thats why i wanted to know if he checked the rear cause that would suck if you had the same problem.
a spacer probaly would of helped but ther not that safe then you would probably have to roll the fenders . i mean 1/4 panels
matter of fact blkralliart04 posted a sticky of all the wheel sizes that fit our car ,you should check it out to see if they carry any of those sizes in the wheel you like.
Registered User
Yeah I did check that, he says 18x7.5 offset 42 will fit... Unfortunately the wheel I like only comes in 18x8... The offset isn't to big of a deal, offset 40 is easy to find... It's the size that I'm worried about... Rolling the fenders isn't to bad either, as long as it's not to much... Also, especially since the rims I want I can get custom made for the car so they would definately be one of a kinds...
well if you think you can do it i say go for it, im all about havin some one of a kind **** so i know how you feel , good luck with your project. let us know how everything turns out.
