rotors
Old Oct 22, 2006 | 04:05 PM
ralliart 04 21's Avatar
rotors
how do you take of the rotors on the ra , i undid the calpiers , but i still couldnt get the rotors off
Old Oct 22, 2006 | 06:31 PM
reTro's Avatar
I had the same prob. There are screws threaded in to the rotors that you drive a bolt into that are supposed to help "pop" off the rotor, but mine were seized so hard that I ended up stripping out that thread.
What ended up working was to WD40 the **** out of it, wrapping the rotor in a rag, and taking the biggest hammer I could find to knock them off.
Good luck!
Old Oct 22, 2006 | 07:56 PM
Myszkewicz's Avatar
If you take off the caliper, you can use a big bolt and nut to push the rotor off. Put the biggest bolt that will fit through one of the caliper mounting holes, and thread it into a nut that's between the caliper mount and the rotor.
Then hold the nut with a wrench while you tighten the bolt. It'll push the rotor right off. If it's really stubborn, you might have to turn the rotor a quarter turn and repeat. I've never had one NOT come off using this method, even when torching and pounding didn't work.
