engine mounts
Old Nov 1, 2006 | 03:05 PM
chowetime's Avatar
it is not so much I am afraid of the mounts I know it is something that will need to be addressed very soon - I just don't like the idea of buying something and finding out it is not really how I want it to be... but if you are saying that the RRM mounts are that good then maybe I should have a much closer look - I know these things are heavy so transport cost could be a killer this is the other reason why getting something more local could be a better option vs O/S there are plenty of Evo owners over here that race there cars and if they have swapped out there factory mounts then I could probably pick them up...
with your mounts how many did you change over?
Old Nov 2, 2006 | 12:15 PM
DangerousDan's Avatar
I changed the front and rear mounts. They are "roll stoppers" and the side ones are mounts. The rear mount is a huge pita but I have a writeup in the diy forum that may help a little.
the guy I mentioned with the civic replaced the mount and bought inserts instead of solid mounts and his car vibrates far more than mine does.
