rear brake bolt
Old Jul 25, 2017, 12:56 PM
bug
bug's Avatar
rear brake bolt
Anyone have trouble removing the top rear bolt from the rear caliper.
last time I did pads i didn't remove the top pin, just swung them up and eventually the pins are sticking-stuck.Question is-you can't get a ratchet or anything on the bolt head cause the brake line is in the way.Now they are on tight.Do I need to remove the brake line? and do I have to remove it at the caliper or up higher? Anyone have any tricks or experience with this.
04 sportback ralliart-
Old Aug 11, 2017, 06:39 PM
CrAnSwIcK's Avatar
it's impossible to remove without removing the brake line, which sucks cause then you HAVE to bleed. removing it from the caliper has less likelihood of breaking something, but it doesn't swivel so the caliper has to be off to completely remove it, you can break the torque before hand...
Old Aug 13, 2017, 08:39 AM
bug
bug's Avatar
I just put on a set of inexpensive pads at the time-can still swing it up to replace pads and it seems less sticky now however i am planning to replace the rear rotors and pads soon anyway and might as well update to stainless lines since it all has to be removed ,replaced and bleed anyway.
Seems like a bad design flaw-could have been made to be out of the way of a socket wrench.
Old Aug 13, 2017, 09:38 AM
4b11slayer's Avatar
Remove lower bolt.
Lift up caliper and slide out top slider pin with bolt still attatched
Old Aug 14, 2017, 07:46 AM
bug
bug's Avatar
slide out top slider pin with bolt still attatched ?
04 ralliart -no pins just 2 bolts and it seems rear brake line must be removed from body and then from the caliper to get a socket on the bolt
Old Aug 14, 2017, 08:19 AM
4b11slayer's Avatar
Pic?
How about bending hardline
Old Aug 16, 2017, 05:56 AM
bug
bug's Avatar
Ok I think I get it
Remove the complete caliper with/including the mounting bracket and then remove brake line from caliper to have access to the top bolt. Loosen tension from brake line connection and spin caliper since brake line doesnt swivel.Remove top swivel bolt with ratchet and socket-cleanup and lubricate and put bolt back in,replace brake line and attach complete caliper essembly to wheel,swivel up on newly lubricated top pin, change rotor and pads-reessemble and bleed.
I would have trhought more people would have run into this.
Old Aug 24, 2017, 07:26 PM
Alex.435's Avatar
I recently had to suffer through this too...I ended up cutting the top bolt with a hacksaw.
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
Nov 5, 2009 03:40 PM
DrivelineSales
Evo 'For Sale' Suspension / Brakes / Handling
Sep 24, 2009 01:04 PM
Fizz Autosports
124
Sep 14, 2009 07:26 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
Quick Reply: rear brake bolt
