Are all oil filters the same?
Just ran across this site:
http://www.synlube.com/prod06.htm
More expensive, but worth it if they'll keep your oil nice and clean. While you're at it, throw on a strong magnet.
That's what I found to be the most impressive, too. $20-30 isn't that much to spend every other oil change at least. Especially is you're really trying to make your car last.
On a somewhat similar note, someone on the X engine forum informed me that the oil is filtered after the oil pump, which means that with a little bit of hardware, you can install a pre-luber type device without drilling into the block. Another good way to prolong engine life.
