ECUflash for Ralliarts
Old Jan 30, 2009 | 01:14 AM
gunzo's Avatar
https://www.evolutionm.net/forums/ev...-released.html
How to get it ..
I've included the Ralliart XMLs for colby's release
the series should be 536000xx
tune your own ralliarts
Old Jan 30, 2009 | 03:13 PM
madcows's Avatar
Good stuff! Hopefully an easy to use logger will be available soon.
Oh, and btw, how similar are those XMLs to the ones for some of the X's?
Old Jan 30, 2009 | 08:52 PM
gunzo's Avatar
If you're referring to addresses .. they are totally different ..
If you're referring to the tables / maps .. they are almost similiar (but VIII/IX are also similiar)
If you're referring to control strategy .. the ralliart has alot less and you can't just load an X ROM onto a ralliart ..
Just download one and have a look .. you'll understand what I'm saying ..
Old Jan 31, 2009 | 05:30 AM
JONralli09's Avatar
i dont understand how this works..what hardware you need for this?? can someone explain
Old Jan 31, 2009 | 05:39 AM
madcows's Avatar
You need something like the following:
http://www.tactrix.com/product_info....5958ecf5f20c3c
The adapter is basically a bridge between the car's ECU, and your computer w/ECUflash.. This software allows you to modify many parameters (typically maps) to tweak performance/economy. If you would like to understand this procedure a bit better, check out this thread:
https://www.evolutionm.net/forums/ec...-tune-evo.html
