Tein Coilovers and Springs
I don't know much about Tein, but I'd stay away just for the reason that they're listing the spring rates as the same as FWD lancer springs that they are also in the process of producing. Couple other companies are doing this also (T1R etc.) selling GTS/Ralliart springs.
While the springs and struts may physically fit from the ES, GTS etc, weight distr. spring rates and valving have got to bifferent for the AWD car vs FWD car. IMHO sounds like an easy way to make your car handle like a wheelbarrow.
<- has 2-3 years on S-techs.
If you're not able to clear the fender, but you don't need much more space (1/2" or so) then you can roll the fenders to gain that clearance.
Is it hard to roll the fenders? How much would it cost and what do they do exactly. I never had to roll fenders on any of my cars this would be the first.
Does it have a negative impact on the car or the car drivability. Please inform me this would help me alot.
If you notice the spring rates that they listed are the same for the FWD lancer ES right above it.
Swift has springs in the works too. http://www.swiftsprings.com/
