Blitz Throttle Controller
Old Mar 16, 2009 | 07:49 AM
Bom's Evo's Avatar
This looks like a good product from the review. I believe it could help get off the line alittle faster, because I know there is a lag in 1st from the clutch engaging and feathering. Drive by wires....
https://www.evolutionm.net/forums/ev...ontroller.html Blitz Throttle Controller
Old Mar 16, 2009 | 07:52 AM
havock28's Avatar
hmmmmmmmmm wonder what that would do to the programming of the ecu..
Old Mar 16, 2009 | 07:56 AM
lancerdave86's Avatar
hmm that should help the lag the lag the car has off the line
Old Mar 16, 2009 | 08:26 AM
slyman's Avatar
This looks good!! Don't know if this will work with our TC-SST since the MR's has a different settings unless I am mistaken? But I would definitely buy one for this is worth!!
Old Mar 16, 2009 | 08:57 AM
Bom's Evo's Avatar
The MR and RA SST trannies aren't that far different.
This just increases the voltage to the drive by wire. Kind of like tightening the a loose throttle cable. But this is alot more noticeable because the wire isn't loose....haha
Old Mar 16, 2009 | 09:54 AM
slyman's Avatar
Thanks for the input. I am used to the old school cable system, not the drive by wires. But that is good to know the noticeable difference.
Old Mar 16, 2009 | 02:41 PM
ambystom01's Avatar
This basic system has been discussed again and again and again. As said, it works by amplifying the signal to the ECU, but that's it. It doesn't change the way the ECU interprets that signal, the way the transmission reacts to that signal or the power the engine makes. It is the same as slamming the gas. I know people argue left and right that it's not but so far no one has explained why it's not.
