4B11T Applications
Old Mar 16, 2009 | 10:02 AM
EsRt2evo's Avatar
4B11T Applications
Can someone please direct me to some pictures, press release, PDF or SOMETHING stating that the RA has the same semi-closed block design as the Evo X. All findings up until now have said its the same, yet since the gen coupe has surfaced, EVERY magazine has stated its the same open deck 4B11 used in the new RA. Anyone?
Old Mar 16, 2009 | 10:56 AM
jazket's Avatar
Go to mitsubishicars.com see if you can find something more informative there.
Old Mar 16, 2009 | 11:38 AM
DatRAzn's Avatar
Here you go, quotes taken direct from their articles
Edmunds
The engine itself is identical to the one in the Evo, right down to the 86mm-by-86mm bore and stroke, semi-closed-deck block and forged crankshaft and pistons.
Zer Customs
Mitsubishi Press Release:
The new-for-2009 Mitsubishi Lancer Ralliart is based on the Lancer GTS platform, adopting powertrain and 4-wheel drive technology from the Lancer Evolution. The result is a unique model optimized for exhilarating yet balanced overall road performance. The Lancer Ralliart gets a modified version of the Lancer Evolution 4B11 T/C turbocharged/intercooled 2.0-liter DOHC MIVEC engine, teamed with the Twin Clutch-Sportronic Shift Transmission (TC-SST) from the Evolution MR model.
The 4B11 T/C is an intercooled-turbocharged 2.0-liter DOHC inline four-cylinder engine built with a cast-aluminum cylinder block and cylinder head. Although based on the architecture as the 4B11 naturally aspirated engine, the 4B11 T/C starts with a unique semi-closed deck block casting and is reinforced for turbocharging. Likewise, the internal components are reinforced to withstand high levels of boost. An integrated die-cast ladder frame contributes to engine block strength and also helps reduce noise, vibration and harshness (NVH) levels. High internal rigidity helps ensure smoothness, and so the 4B11 does not use a balancer shaft.
If you follow the VIN decoder provided by mitsu off of mitsubishicars.com, the X and the RA have the SAME TC/IC 4B11.
Mitsu VIN decoder
X VIN: JA3AW86V98U043503
RA VIN: JA3AV66V79U023680
11RAturbo
May 30, 2015 02:45 PM
GTSFrickle32
Jan 23, 2015 07:53 AM
theblackbeast11
Oct 10, 2013 12:05 PM
sirchumpalot
12
Feb 27, 2013 06:51 PM
Exyia
97
Sep 8, 2011 10:22 AM
