Boost Pill
Old Mar 28, 2009 | 05:09 PM
Tzacks's Avatar
Boost Pill
I've said this before, but i'm a complete car rookie. I'm learning as i go :P
Can someone please explain to me what a boost pill is? And perhaps how one goes about installing one?
I plan to get the ecu flash + boost pill for my RA soon, but not much else. Just wondering what the sweet hell a boost pill is/does!
Thanks
Old Mar 28, 2009 | 05:26 PM
silthos's Avatar
pm'ed
Old Mar 30, 2009 | 09:52 AM
08Lancer89's Avatar
can you just post the info here im sure others would liek to know how to install one. I want to get one also.
Old Mar 30, 2009 | 10:47 AM
bossssman38's Avatar
same.
Old Mar 30, 2009 | 11:09 AM
silthos's Avatar
Will do when I get off from work.
Old Mar 30, 2009 | 09:48 PM
silthos's Avatar
boost pill is in the middle clamp
All you have to do is pop the hood and find those clamps. Get a needle nose plier and loosen all three clamps. Remove part of the hose from the t. Then remove the other part of the hose from a small black line. You might need a flat head screwdriver to take loosen it up. Once you have the hose off, take a small Phillips screwdriver and insert it into the hose to push out the stock pill. Insert the new boost pill and make sure you put it in the middle clamp before the t. Hook everything back up. Remember, you must have a flash for the boost pill. If you decide to put the stock map back on you must put the stock pill back in.
Old Mar 30, 2009 | 10:21 PM
ExcessLancer's Avatar
how does it work.. what does it do??
Old Mar 30, 2009 | 10:25 PM
silthos's Avatar
it helps control boost without having to use a mbc. just take the stock one out, replace with new one and tune. More boost = more power!
Old Mar 31, 2009 | 06:29 AM
Piper747's Avatar
The "boost pill" restricts the air flow from the compressor to the waste gate actuator, and solenoid. As a result, the actuator does not have to run as much duty cycle to divert air pressure away from the solenoid allowing more boost to build up. The actuator is a transistor switch that toggles back and forth either diverting air from, or allowing air to reach and build up at the solenoid. Once enough pressure builds up, the solenoid opens the waste gate releasing the boost pressure. From the factory the WGDC maps are maxed out in allot of areas which is unnecessary once "the pill" is in place. To prevent over boost and uneven boosting you must get a reflash.
Old Mar 31, 2009 | 06:52 AM
silthos's Avatar
Originally Posted by piper747
the "boost pill" restricts the air flow from the compressor to the waste gate actuator, and solenoid. As a result, the actuator does not have to run as much duty cycle to divert air pressure away from the solenoid allowing more boost to build up. The actuator is a transistor switch that toggles back and forth either diverting air from, or allowing air to reach and build up at the solenoid. Once enough pressure builds up, the solenoid opens the waste gate releasing the boost pressure. From the factory the wgdc maps are maxed out in allot of areas which is unnecessary once "the pill" is in place. To prevent over boost and uneven boosting you must get a reflash.
+1
Old Apr 2, 2009 | 05:30 PM
08Lancer89's Avatar
sweet can you circle where the pill is please
Old Apr 2, 2009 | 05:35 PM
craigb3's Avatar
The clamp above the yellow part in the middle of the picture. Its located right in front of the firewall between the firewall and the top of the engine.
Old Apr 2, 2009 | 05:42 PM
08Lancer89's Avatar
Old Apr 2, 2009 | 05:49 PM
silthos's Avatar
just the middle clamp
Old Apr 2, 2009 | 07:17 PM
08Lancer89's Avatar
So the middle clap that's circled right? Jut that one holds the pill so that clamp hold the middle of the pill correct.
