Factory turbo timer
Old Oct 7, 2009 | 08:41 AM
DarkCloud2049's Avatar
Lightbulb Factory turbo timer
I dont know if anyone noticed but when shutting off the car, theres a 2-3 sec delay before shutting down. Is it possible the the RA has a factory turbo timer and if it does are we able to adjust the time to allow the turbo to cool down before shutting down. Figure a good minute than shutting down or an aftermarket turbo timer is needed. I always give the car a good 2 minutes to cool down from a long drive than shutting down.
Old Oct 7, 2009 | 08:42 AM
ambystom01's Avatar
No, this has been discussed before, that's not a turbo timer.
Old Oct 7, 2009 | 08:44 AM
K thanks, Im a nooob to the forum.
Old Oct 7, 2009 | 08:56 AM
fugiwara's Avatar
Look, you don't have to allow the turbo to cool down if you didn't race the engine prior to coming to complete stop. Allowing the car to cool down 2 mins is waste of gas, period!! I have a APEXi turbo timer, I put in auto mode, it will basically check and see if the engine needs to be delay shut off, most of time it nevers delay shut off, only when I rev it while trying to park in the garage then it will delay shut off for no more than 30 seconds.
Old Oct 7, 2009 | 09:25 AM
japan101's Avatar
It is the transmission clutches and gearing disengaging.
Old Oct 7, 2009 | 10:58 AM
vito's Avatar
lol.. i thought it was a turbo timer as well :P
Old Oct 7, 2009 | 02:46 PM
djwon's Avatar
the dood at the mitsu dealership says theres no need for turbo timing in the new evo/ra's. thats not correct is it? cuz i think hes crazy :X
Old Oct 7, 2009 | 03:02 PM
DatRAzn's Avatar
Unless you peak boost down your street, and up your driveway. There really is no need to get a turbo timer for the X/RA...I forget where I read this from...I'll try to find it somewhere.
Old Oct 7, 2009 | 03:55 PM
Jyrk's Avatar
every where i go its always peak boost.. from light to light, through the car wash, up my driveway into the garage. Then i instantly shut it off before i even put it in park.
Old Oct 7, 2009 | 05:23 PM
ambystom01's Avatar
He's right, unless you're really really hard on the motor, it's unnecessary.
Old Oct 8, 2009 | 06:51 PM
03chi-town0Z's Avatar
^ exactly what i was going to say. and even if you are, and you shut it off with very high engine/engine bay temps, there is an after-run fan setting that will engage your cooling fans automatically even while the car is turned off, hence that little sticker on the cowl that says "Caution, electric fans may come on at any time...blah, blah..." you know the one.
Old Oct 8, 2009 | 08:11 PM
Fourdoor's Avatar
Another factor in not needing a turbo timer is running full synthetic Mobil 1 oil. In the bad old days of oil pumped up out of the desert sands oil was MUCH more likely to coke up on the turbo bearings if you shut down right after some high performance driving. Even then if you didn't drive too much like a jackhole you were fine.
Keith
Old Oct 8, 2009 | 08:13 PM
MatosEvo's Avatar
Turbo timers are not as necessary nowadays. Most timers wont even keep the car on unless you were running the car hard just before parking.
Old Oct 8, 2009 | 08:21 PM
kblock4life's Avatar
really if it was nessecary and needed on the car they would have put it on from the factory.... but then again, it says in the owners manual after hard runs to let the car run for a 1-2 min
