Rattle from behind the dash.
Old Nov 29, 2009 | 12:37 PM
ralliartblitz's Avatar
Its v.annoying problem
Old Nov 29, 2009 | 07:50 PM
xi's Avatar
xi
Originally Posted by Taranis
On mine at least it's just the door, and from what the guy right after me described it sounds like his is the same thing. When it starts doing it if I just press on it a little it stops, and then re-shutting it makes it quit for a while until it loosens up again. One of these days I need to open it up and see if I can tighten some things down. =)
-Taranis
Do u have a lot of stuff in your glove compartment?
I have quite a bit of crap in there and I'm sure it helps dampen the vibrations in there.
Old Nov 29, 2009 | 08:07 PM
RGRalliart's Avatar
I have a rattle from the glove box, the passenger seat makes noise, the wind noise at highway speeds and the lack of sound deadening. Build quality isn't a high priority but for the price what do you expect?
Old Nov 29, 2009 | 10:58 PM
Taranis's Avatar
Nope it's pretty empty; mainly just the car manual and the necessary papers. Good point though; I'll try to put some extra stuff in there and see if it helps. =)
-Taranis
Old Dec 1, 2009 | 11:05 AM
Talaryn's Avatar
I noticed a rattle seemingly coming from my dash as well :/
If I press on the panel near to the volume knob, the subtle rattle disappears. I noticed it is the worst when I first start the car.
Old Dec 1, 2009 | 05:52 PM
2010RALLIART's Avatar
Mine is only one week old and I have the glovebox rattle. I have to find something to fix this. I was thinking about adding some kind of spacer to make the door fit tighter.
Old Dec 1, 2009 | 07:54 PM
xi's Avatar
xi
Try using some stick on foam. You want the open cell version that really collapses down.
Old Dec 5, 2009 | 03:10 PM
jRox's Avatar
Originally Posted by bmanuhutu
i get an annoying rattle from my passenger glove box, either something inside or the handle vibrates, because when it starts doing that usually 2000-3500 RPM, i just open and close it , and it disapperas, and yes something behind the dash vibrates. :!!!!!!!!!!!!!!!
damnit mitsu come on, my evo 8 was a better build quality then this no rattles no nothin.
The glove box rattle is sooo annoying.
