Help warning lights!
Old Jan 20, 2010 | 03:15 AM
  #31
08Lancer89's Avatar
Originally Posted by tjac357
the sensors that send info to the AWC system. I got mine fixed under warranty. I could find out how much they were without a warranty if you wanted. Just wanted to give you a heads up, since they're apparently very delicate.
where are they located
Old Jan 20, 2010 | 09:02 AM
  #32
tjac357's Avatar
They're all the way behind the center console right up to the firewall. I didn't do it since it was warranty work but talked it over with my tech when they were doing it.
Old Jan 20, 2010 | 11:05 AM
  #33
C H's Avatar
C H
Since there was so much damage, are you sure a wiring harness didn't get unpluged or torn apart? I would guess they only use the ABS sensor but you never know, might be worth taking a look to see if something got unplugged.
Old Jan 20, 2010 | 12:36 PM
  #34
08Lancer89's Avatar
so look under the dash
Old Jan 20, 2010 | 01:37 PM
  #35
tjac357's Avatar
Yea just really far back. I don't know if you can visibly tell if it's damaged or if you need to scan the computer.
Old Jan 20, 2010 | 01:45 PM
  #36
EvolNinja's Avatar
I'm guessing you do too much launch and messed up the TC so it needs to be serviced?
Old Jan 20, 2010 | 02:45 PM
  #37
tre's Avatar
tre
did you even read the whole thread? he clearly stated he had a tire blow out and cause additional damage.
Old Jan 20, 2010 | 03:06 PM
  #38
08Lancer89's Avatar
I have NEVER launched this car
Old Jan 20, 2010 | 03:28 PM
  #39
08Lancer89's Avatar
dont think I have any loose connections anywhere, I drove down my street and back a few times with the sapere on no lights came on until I was pulling back up to my house lol, I did have the battery out of the car and now its back out, so i think you guys might be right that its just the spare.
Old Jan 20, 2010 | 08:28 PM
  #40
tre's Avatar
tre
evom to the rescue
Old Jan 20, 2010 | 08:39 PM
  #41
08Lancer89's Avatar
Well soon find out just waiting on my Rotas now got my new tires.
Old Jan 20, 2010 | 08:42 PM
  #42
turbolagdsm's Avatar
just a reminder for you.when you put the new rims on you need to make sure the tpms sensors get put on the new rims and i think programmed.
Old Jan 21, 2010 | 05:43 AM
  #43
08Lancer89's Avatar
they will some on here say I might not need to be programed since they are already synced with the car.
Old Jan 21, 2010 | 06:23 AM
  #44
velocityhead's Avatar
My understanding of how the TPMS sensors work is this: as long as the sensors are within transmitting distance every time the car is turned on, they will not need to be reprogrammed. I'm not sure what it means if only one of the sensors is not present (in your case). A tech explained this to me...I'm not sure how accurate it is, but it makes sense.
Old Jan 21, 2010 | 08:05 AM
  #45
lancer0220's Avatar
as long as t he tpms was not damaged when you had a blow out and it is still reusable you should not have to reprogram just transfer over
done this twice on an 08 es and 09 gts...
