erratic idle....
Old Feb 11, 2010 | 10:17 AM
T67@20ART's Avatar
erratic idle....
Sometimes once in awhile, while at a stop light my idle RPM would be erratic and unstable yet has never died. It would last a few seconds then back to normal, a friend said it maybe a vacuum or pressure leak. I would appreciate any thoughts or feed back if anyone else is experiencing this problem. I guess time to make an appointment to the dealer....
Old Feb 11, 2010 | 10:33 AM
DatRAzn's Avatar
I saw this issue in the X forums awhile back...it may or may not be the same issue. But worth checking out. It turned out to be a simple vacuum hose that popped off and causes idle to be all screwy.
https://www.evolutionm.net/forums/ev...s-do-asap.html
Old Feb 11, 2010 | 11:49 AM
T67@20ART's Avatar
Well I checked the hose and it's still on, I will remove the cover and check the other end later, hopefully some hose clamps or zip ties will prevent the crazy idle....
On a side note just replaced the stock yoko's and wow I really didn't realize how badly the inside thread was warn out, with only 25,000 miles. Good news is with upgraded 225 the car feels so much better....
Old Feb 16, 2010 | 03:34 AM
Willow132's Avatar
I had a similar problem with mine up until recently and was told that it is to do with the aircon.
I tried it with it turned off and it works. So my ecu was sent away to be reprogrammed as there is a know issue over here in the uk
Old Feb 16, 2010 | 06:09 AM
boondoc's Avatar
I have the same issue that happens from time to time and my hose it still on. I forgot to zip tie jus incase its leaking a bit. Yea the stock tires are bad. I'm gonna wait until they are destroyed b4 i change tires, i don't want to ever see them again.
Old Feb 16, 2010 | 09:59 AM
Taranis's Avatar
The AC definitely makes the car idle poorly, so that is the first thing I'd check.
That aside, I do occasionally get random weirdness in the idle, but it only happens occasionally and doesn't last long (except if the AC is going).
-Taranis
