looking for a better aggressive hood
Old Apr 7, 2010 | 07:37 PM
hotsos's Avatar
any suggestion on where to find one
the ones i have seen are the stock ones with just different vents
Old Apr 7, 2010 | 08:21 PM
RotorGlow's Avatar
You can look for Evo X hoods as well, since we share the same one.
Old Apr 8, 2010 | 07:43 AM
gccruz's Avatar
I think our stock one is very nice and aggressive look to it.
Old Apr 8, 2010 | 08:04 AM
RADriver's Avatar
So far I think you are looking at a custom job. Mostly it would involve cutting
inserting gills,vents or scoops or whatever feature you want then tack welding, grinding, sanding and painting.
It can't be to hard heck they do it on Muscle car TV all the time and it only takes 1/2 hour to complete.
For an off the shelf hood I think you are SOL
Old Apr 8, 2010 | 10:26 AM
secondchace's Avatar
get a cf scoop and a front lip. there will be no need for a more agressive hood at that point. Tbh anything done to modify it would look horrible and tacky.
Old Apr 8, 2010 | 10:50 AM
initial_d2k's Avatar
I thin "CW-Style" is pretty nice from Seibon! take a look
it looks almost like Stock ... back the 3 vents is slightly different..
if "big vent/scoop" is ur taste .. check of "TS" from Carbon Creation
Old Apr 8, 2010 | 06:37 PM
03chi-town0Z's Avatar
i was all for the seibon cw style, until i saw the varis. that is the design seibon based theirs on, but the varis has much smoother lines and just looks mean as f***. too bad its like 1600-2400 bucks depending on materials. i got a lot of saving to do...
see here:
https://www.evolutionm.net/forums/ev...ked-white.html
edit: similar styling to seibon cw can also be found on "test and service" hood, and most extreme version of this design seems to be made by a company called maziora. i also found that they offer a frp version of the varis for only 900ish, hopefully it's legit!
