Would it be wise to use Slick 50?
I have had my RA tuned by the folks over at AMS. I was wondering if it would be wise to put "Slick 50" in the car. I have heard that it improves performance and protects the internals of the engine well.
Is there any other product that is recommended over Slick 50?
Its snake oil. Stick to full synthetics like AMSOIL or Royal Purple if you want the extra protection because you run the car on the track. If you only drive the car on the street, Mobil 1, Castrol edge, and the like will suit you just fine.
Slick 50 is teflon, a solid, in suspension. It has been known to clog lifters and oil passages over time. Total waste of money and may damage the motor. All of these additives and treatments are complete bunk. Stick to quality oil and regular oil and filter changes.
i usto use Dura Lube back when they had those comercials about engines that could run without oil without seizing for a few miles,,, it was pretty impressive the test they had,,, i also used it in my 2 cycle nitro methane RC cars, and for sure the piston to cylinder friction felt lesser
I used Slick 50 when I first bought a 1992 Plymouth Sundance(same car as a Dodge Shadow), and that thing never had a problem with the engine and ran over 150,000 miles before I finally got rid of it just because I wanted a new car(It still ran fine though). So, I'm not sure if the Slick 50 had anything to do with that, but I certainly don't have anything bad to say about the product.
Or you could just use Valvoline Power Full Synthetic or MaxLife Full Synthetic. They will guarantee your engine for up to 300,000 miles.
But then again, anyone that changes the motor oil with synthetic every 3,000 miles and is driving a bone stock car will achieve this. This is no revelation. Just regular maintenance will give you this result. Regular maintenance is everything. Do everything by the book and you will have no problems for a very very long time.
