Front door card "carbon" trim
Old Feb 23, 2011 | 10:01 AM
Pave's Avatar
Hi!
Is that carbon look trim at front door card removable??
I´m planning to wrap those interior carbon look trims with more real looking carbon vinyl.
So it is easier to fit vinyl if I can remove those door trims.
Thanks!
Old Feb 23, 2011 | 10:15 AM
total0wnage's Avatar
yes the door trim is removable and so is the dash trim
Old Feb 24, 2011 | 02:26 AM
Pave's Avatar
Ok, great!
I removed dash trim few times earlier so I know that.
And at the door cards... you remove door card and then there is some screws which hold the trim right??
Old Feb 24, 2011 | 03:40 AM
03chi-town0Z's Avatar
yes. just remove the inner door panel and then there are a whole bunch of screws on the inside holding everything in place. there also a few plastic locking-tabs that you need to be careful with when trying to pull everything apart, but the entire door card comes apart pretty much piece by piece. it's just a matter of comparing screw position in back to the piece you'd like to remove on the front
Old Feb 24, 2011 | 07:57 AM
Pave's Avatar
Thanks to all for answers!!
