doing 30k service need HELP
Old May 30, 2011 | 07:22 AM
Allie10's Avatar
i work at shop and i wanna know what front diff oil it takes and am low and also has anyone done a exchange of trans i need to know where the fill is and drain is at. and how do i check if its full when done. bc i dont have a dipstick. thanks
Old May 30, 2011 | 07:44 AM
jkennedy293's Avatar
The front diff and the trans are essentially the same unit. As for the location of the drain and fill plugs, check the how-to section for detailed write-ups.
Old May 30, 2011 | 07:45 AM
Allie10's Avatar
thanks and also is there a book that has all the info i look and no luck
Old May 30, 2011 | 08:42 AM
hixlancer's Avatar
Veteran: Army
look in the how-to sections. there are write ups for all of these. It will also explain how much fluid to add.
edit: click this link...just for you https://www.evolutionm.net/forums/09...er-change.html
Old May 30, 2011 | 03:34 PM
Allie10's Avatar
Thanks
priZm
Mid-Atlantic Region
Sep 26, 2014 04:49 PM
OriginalEvo
Northwest Region
Oct 15, 2011 05:53 PM
andyr2971
Mid-Atlantic Region
Jan 2, 2007 08:29 AM
992gnt
Jul 12, 2003 07:12 AM
