CREE Led Reverse Bulbs
Old Nov 13, 2011 | 05:48 PM
RalliAaron's Avatar
I'm having a problem with these bulbs, when I put them both in, they only stay on for about 10 seconds. But one will stay on if I leave 1 stock bulb in.
Any ideas, like a bigger fuse, or maybe a resistor?
Old Nov 13, 2011 | 07:03 PM
sstevojr's Avatar
I 'think' I remember reading something about this a while ago. IIRC it has to do with the LED's not requiring as much power, and needing some sort of resistor?
Old Nov 13, 2011 | 08:02 PM
RalliAaron's Avatar
But its weird how if I leave one stock bulb in, and one LED bulb in, they stay on.
But if I put both LED's in they only stay on for like 10 seconds. I didnt think it would be a resistor, seeing as LED's are supposed to use less power, but im at a loss, and cant figure this out.
Old Nov 13, 2011 | 08:24 PM
03chi-town0Z's Avatar
Yeah, it's a resistor issue. Adding one to the harness will clear up your issue.
The problem is because with both led bulbs installed, the vehicle doesn't see a normal current draw from the bulbs because they require so little energy to operate, so it automatically stops sending what it thinks is "wasted" power to a lighting system that it believes is inoperative.
When you have one stock bulb installed, it recognizes the draw that it would normally receive from one operating bulb and one burnt bulbs, so it continues to illuminate the system because it believes that it is, at least partially, operative.
Old Nov 14, 2011 | 10:34 AM
RalliAaron's Avatar
Thanks, bought a resistor from AutoZone and that fixed it right up! Thanks alot Chi town!
Old Nov 14, 2011 | 10:58 PM
2muchboost's Avatar
Pics!!!!
Old Nov 15, 2011 | 05:14 PM
RA173's Avatar
50 ohms 6 watts or 50 watts 6 ohms I forget which one is the correct one
Old Nov 16, 2011 | 08:23 AM
RalliAaron's Avatar
Will post pics when I get off work guys! Very simple. And thanks again for the input!
Old Nov 16, 2011 | 11:47 AM
2muchboost's Avatar
You should post a "how to"!
Old Nov 16, 2011 | 11:52 AM
Hennessy2remedy's Avatar
you just explained the reason for a resistor in your sentence haha
glad you figured it out.
Old Apr 4, 2013 | 09:37 PM
08Lancer89's Avatar
Kyle do I have to put one resistor on each plug
Or just one on one side
Old Apr 7, 2013 | 01:35 PM
robyn402's Avatar
one does the trick, I've currently got one 25w 8ohm installed for my reverse lights
Old Apr 15, 2013 | 04:41 PM
GetFoxed's Avatar
I have the same issue, any one going to post the exact resistor & a how - to with Pics? or a Youtube video?
Thanks.
Old Apr 15, 2013 | 05:53 PM
splattj's Avatar
I just used one of these:
10 Ohm/25w Load Resistor for Fix of LED Hyper Blinking / Warning Signal Light : Amazon.com : Automotive 10 Ohm/25w Load Resistor for Fix of LED Hyper Blinking / Warning Signal Light : Amazon.com : Automotive
Hook one wire up to the 12v positive and the other to the ground. It adds 25w of load to the reverse light circuit. Don't go too big or you could cook wiring or pop fuses.
For reference, stock bulbs are 21w each.
Old Jul 16, 2013 | 04:52 AM
PistenBoy's Avatar
I had/have the same issue currently with my 16 watt CREE LEDs. Checking my options with the tuners to see weather I can just have the current value altered to accommodate lower power bulbs. Saves power and don't have to wire in resistors ><
I find that having one of each (LED and Incandescent) works for the time being.
I took a photo to illustrate the difference in light output and pattern from the two bulbs.
Guess which one was the CREE chip? =P
