aem wideband gauge question
Old Mar 27, 2012 | 07:54 PM
robyn402's Avatar
Soo... i put my aem wideband in finally and im curiois what afr's people get at idle, cruising, WOT as currenty mine is all over the place when i'm on the highway doing steady speed & rpm and when i'm at idle it bounces between 14.2 - 15.6 constantly
Currently using an etune for the mods in my signature
Cold start
Cruising 60kph @ 2000rpm... relativly flat ground
highway throttle
Old Mar 27, 2012 | 08:09 PM
Struc's Avatar
That's called closed loop operation, and it's normal. It's supposed to bounce back and forth between slightly rich and slightly lean.
At WOT, the ECU goes into open loop, and the O2 sensor is ignored and the ECU maps are used based on airflow, temp, load, etc, etc.
Old Apr 7, 2012 | 12:08 AM
robyn402's Avatar
good to know, decided i'd toss some videos up.. sorry for the shaky camera
Old Jun 29, 2014 | 08:14 AM
danike's Avatar
Why does the wideband need to be grounded when you hook the blue wire up to a serial-usb cable? It says ground pin #5, but i hooked mine up without grounding and it still works.
robyn402
Dec 14, 2014 12:03 PM
robyn402
Nov 24, 2013 04:15 PM
robyn402
09+ Ralliart Show and Shine
18
Feb 11, 2011 09:06 AM
robyn402
Feb 10, 2011 10:58 PM
robyn402
For Sale - Wheels / Tires / Suspension / Brakes
Aug 12, 2009 11:54 AM
