2 cars, one key
I'm not sure if this is the right place for this, but here goes...
I'm picking up a new 2013 WW Ralliart tomorrow, and I already own a RR 2013 Outlander XLS. Is it possible to reprogram the FAST key system to be able to use one key fob on both cars? I know that I'd also have to have the tumblers changed to match, but I think the proximity system would be the real sticking point.
Any thoughts?
Any thoughts?
That sounds like a good idea! But unfortunately as far as I know each key has a specific program and or frequency set for each car. Unless you can reprogram your car's transmitter or get one to match your current car you wont be able to use the same wireless key for two cars.
It would be nice though =D
No, you'd still have to physically hit the button on the door handle to unlock the car, so only the car you want to unlock would open.
Makes sense about having to replace the transmitter - I was just hoping they could reprogram it rather than replace it.
To be clear - you would have to re-program one vehicle to exactly match the other - the key can't 'remember' two vehicles... And the back up metal key would be wrong 50% of the time...
Ahh that seems logical, i forget newer cars have this option when the keys in your pocket to touch the button on the handle and it unlocks the car. id still be skeptical and personally i doubt Mitsubishi will do it for you but i may be wrong.
So it looks like we should have all trusted our instincts on this one - it's a no-go.
The reason isn't one I would have guessed, though. It isn't because the dealer refused to try it for security/warranty/aliens, it's because every time they program a new key to the car, it creates a new and unique code that the keys and car share. So they would program for car A, then reprogram for car B which wipes the code for car A from the key.
It's too bad - even the service manager at the dealer wanted to see it work, but could figure a way around it. Apparently I'm the first person to ever ask for this too.
Evo1001
27
Jan 16, 2012 11:52 AM
Proteus_x15
Mar 18, 2011 04:27 PM
killabee
14
Aug 28, 2010 03:38 PM
