lights and engine code P061a
Yeah I think this recall changed the torque tables like you said from over boosting in the cold winter from what I understand and the dealer said. I wouldn't worry about it unless it happens again or you get a recall notice. You could always call your local dealer and have them run your vin for open recalls or tsb or anything.
I have the same code popping up even after the reflash then I go wot threw a few gears and my service engine light comes on and when I stop my car idles at 1500-1700 but then I shut it off and turn it right back on and idles normal
Is it just the check engine light that comes on or other lights too? Do you know the code? Looking at the list of your mods I would say check you tune and make sure no intercoolers or couplers are leaking. Make sure theres no vacuum leaks. Did you check the hose under the plastic engine cover for the spark plugs? sometimes that comes off. Make sure the boost gauge T isn't leaking. Some people say the oil from the k and n air filters burn on the MAF sensor but I have one and havnt seen this happen. I would clean that with MAF cleaner. The code would be the most help. I havnt had any issues with the reflash or know anyone who has from the dealer.
P0513 - Immobilizer Malfunction
TECHNICAL DESCRIPTION
•ECM monitors the communication condition with the immobilizer-ECU. When an abnormality in communication is found, ECM prevents engine start.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are
•CAN system failed.
•Immobilizer system failed.
•ECM failed.
P0456 - Evaporative Emission Control System Leak Detected (very small leak)
•The ECM monitors the Evaporative Emission (EVAP) System pressure.
•The ECM controls the evaporative emission ventilation solenoid. It closes the evaporative emission ventilation solenoid to seal the evaporative emission canister side of the system.
•The evaporative emission purge solenoid is opened to allow manifold vacuum to create low pressure (vacuum) in the EVAP system.
•When the EVAP system develops a vacuum of 2 kPa (0.29 psi), the evaporative emission purge solenoid is closed and the fuel system vacuum is maintained at 2 kPa (0.29 psi).
•The ECM determines whether there is a leak in the EVAP system by monitoring the vacuum inside the fuel tank.
•The test is stopped when fuel vapor
TROUBLESHOOTING HINTS (THE MOST LIKELY CAUSES FOR THIS CODE TO BE SET ARE
•Loose fuel cap.
•Fuel cap relief pressure is incorrect.
•Malfunction of the evaporative emission canister seal.
•Malfunction of the fuel tank, purge line or vapor line seal.
•Malfunction of the evaporative emission ventilation solenoid.
P0068 - Mass Airflow Sensor Plausibility
Compare the actual measurement of volumetric efficiency by a mass airflow sensor signal with volumetric efficiency estimated from a throttle position sensor (main or sub) signal.
•Mass airflow sensor system failed.
•Intake system vacuum leak.
•There is some foreign matter around mass airflow sensor.
•Intake charge pressure failed.
•Intake charge pressure control system failed.
•ECM failed.
•CAN system failed.
•ECM failed.
•Loose fuel cap.
•ECM failed.
New maf check already done still came on so I cleaned it and cleaned my filter took every chemical off of it put it back in still came on the big problem is when I go wot from 1 st 2nd gear and run it to around 6k then I stop my car revs at 1500-1700 rpm then I let it sit still no change but I turn it off and right back on and car idles normal but other than that the car runs perfect no boost leak I have checks all my hoses no leaks I am taking it to mitsu this coming week and having my buddy look at it he is the tech who works on my car there I know I didnt do correct punctuation its just one long sentence lol oh and by the way Happy Easter
Yeah no problem I don't worry about correct punctuation lol. I Would go back to stock factory ECU instead of any kind of tune disconnect the negative battery and let it sit a while and let the ECU reset. Than give it a few days and some miles. Than try that, that should tell you if it has anything to do with the tune. I'm glad you have a buddy in with a dealer because 9 out of 10 times they don't want to know nothing even worse with mods. Other than that check live data when you do a pull and see if you can see anything. Do you have anything that you can do data logs with? Yeah happy Easter to you too,
I can't flash it back to stock bec I don't own a traxis cable or how ever you spell it lol I had a friend flash it when I was in jersy for mod in 2012 I just have the stock map on my computer though unless someone who lives in western md or southern pa wv that has one and could help me out would be awesome
Yeah that sucks, try to find one cheap on EBay or someone selling one on a forum. It might not be the tune anyway I way just trying the easy ways to eliminate the things that can be causing these problems.
Code P061A
On way home from work it was 19 degrees a milefrom my home the car went into limp mode and turned on the asc service light andtransmission service light also the check engine light on with code po61A. I looked it up and it said something about torque. Bothother lights went off after two restarts and car sitting for a few minutes. I erased the checkengine light code myself. quick test drive seemed ok. The car has 11160 miles and the only after market things are a auto meter boost gauge and subs in the trunk. I just did the sub work over the weekend but think its unrelated and might be the cold since it hasn't been that cold here since I owned the car 4 weeks lol. Its a 2011 ralliart, I looked on here and seen a few people have had a issue with this but I cant seem to find a deff answer. The closet dealer is hours away and is a pain to get in. Any info would be great, I don't thing its a boost gauge leak because the gauge was reading right the whole time.
FS[Pacific NW]: RR 08 X GSR, SSS, Aero, Bolt-ons
JimGVT
For Sale - Cars For Sale
Jul 21, 2015 05:48 AM
Velsonic
18
Jun 6, 2014 05:57 PM
jason42003
Jan 20, 2014 12:34 PM
