Hot Smell Coming From Vents
So as anybody who has been affected by the recent snow storm knows, the weather has been really bad/cold lately. I just bought my RA in August and I am very careful with it. I have noticed recently that when running the air (initially I noticed with heat and now it seems to be both) I smell this hot plastic smell. It gets worse when I'm driving in snow or rain, especially the snow. Is this because of stuff from the road going somewhere and causing something to burn?
The heater also doesn't blow hot air when I'm idling, is that a normal RA thing? Keep in mind I have a huge intercooler and aftermarket Radiator from the original owner. Could the combination of those be doing anything since I'm on the stock tune?
Sorry I'm just trying to give as many details as possible.
Thanks!
Thanks!
Yeah I'm kinda thinking I might run it to the dealer just in case
I have a faint plastic smell coming from my vents as well. Attributed that to mine just being a new car. When I pop the hood when the car has not been running for the night, i smell plastic from the engine bay. I'll check my fluid levels as well
I know when I had something spill onto the exhaust manifold heat shield (went through the hood scoop) that it cause a bad smell in the vents for a few days until I pulled off the heat shield and cleaned it all off.
You might want to see if something is resting on yours causing the smell.
With the valve cover being composite and our engines run warm normally there will always be a faint plastic smell I think.
So I checked the coolant level finally (I've been busy and spaced it until I smelled that smell again today) and my coolant level is low, it is about 1/8" below the "Low" mark. Any special coolant that I need to put in this thing or just some from Autozone or something?
No it defrosts pretty well actually. I haven't smelled it since I refilled the coolant. I drove it a little harder for a bit and still didn't smell anything so I think that might've been it. I'm pissed that the dealer clearly didn't check it though.
