11 sec. ralliart hp guess
Old Oct 26, 2014 | 04:17 PM
Ralliart09er's Avatar
FINALLY got my 09 ralliart back together and running. Seeing what guesses people think my power will be at. Getting tuned friday, so pumped. Dyno dynamics dyno. Before I was at 345whp 343wtq. Im still stock bottom end so im limiting myself to 360wtq as that is a low reading dyno.
Mod list:
Map ef3
Gsc S2 cams
gsc behive valve springs
arp headstuds
map tubular short runner exhaust manifold
map downpipe w 02 dump
Turboxs catless catback
buschur intercooler
ultimate racing intercooler piping
grimmspeed 3 port ebcs
Deatschwerks 1000cc injectors
Walbro 255lph fuel pump
ultimate racing intake
ssp flywheel
ssp 500hp clutch
ssp trans cooler
ssp trans fluid
ssp aluminum trans filter
ssp clutch plate springs
tuning with cobb accessport
E85
Old Oct 27, 2014 | 07:09 AM
Bump
Old Oct 29, 2014 | 09:24 PM
spider21's Avatar
Your going to need a bigger fuel pump
Old Nov 3, 2014 | 03:44 PM
JoshB's Avatar
I'm going to go out on a limb here, but are you going to kaizen tuning?
And definitely need a better fuel pump, I was told I needed one for 315whp
Old Nov 3, 2014 | 03:49 PM
I goto DB Performance out of Rogers, MN. On stock X turbo I was pushing 345whp 343wtq on that pump. My tuner said. ill be fine. I had wastegate issues on the dyno and ended up not able to get tuned. Pretty sure MAP put the wrong rod on my turbosmart gate. To short. Couldn't get it under 30psi. Tossed the stock gate back on n now its in storage
Canexican
Nov 9, 2013 07:46 AM
DocCola
Sep 10, 2008 02:56 PM
babykyle
84
Feb 27, 2005 02:02 AM
EvoDaCunEvil
20
Oct 27, 2002 07:00 PM
sblvro
Mar 24, 2002 09:46 AM
