Heater on causes vibration?
Old Dec 24, 2014 | 05:49 AM
khami's Avatar
Hey guys,
Got a weird issue, not sure if it's just a one off thing. About 30 minutes ago I started the car and I turn on the heat. I was idling for no longer then 3 minutes and everytime the car make a click noise (common thing I hear since Day 1 of owning the car - purchase new) the car vibrates and it's VERY noticable.
When I turn the heat off this doesn't happen. When I have the heat on and driving it doesn't happen. When I have the heat on and driving and finally get to where im going and park it, I feel the vibration again.
Thoughts? No check engine or anything and did all the maintance recently at 60k (at 62k currently).
Thanks
P.S. It's a grinding noise along with the vibration felt throughout the car. VIdeo uploaded. Blower motor is done?
Old Dec 26, 2014 | 12:06 PM
neogeo64's Avatar
sounds like something hitting your radiator's fan blades.
Old Dec 29, 2014 | 05:56 AM
Veronica's Avatar
Is the compressor on (windshield defog setting)?
If it is fine in the floor heat (a/c button 'off') then your a/c compressor may be getting ready to fail.
If it is related to fan speed (independent of any other setting (i.e heat/defog, etc.) then it may be some debris in the blower/fan motor. Drop the blower motor and inspect.
Old Dec 30, 2014 | 11:42 PM
Flexkilz's Avatar
Wish I could be of help, but I might add I get the same issue whether the A/C is running or not. In Tucson we've recently started freezing up on a daily basis, and the car makes tons of noise; random tapping sounds in the dash going over bumps, seat belt areas creaking, similar plastic rattling sounds in the rear, etc.
Old Dec 31, 2014 | 05:14 AM
Veronica's Avatar
So listened again to the video (which really helps)...
Hopefully it is only a bad tensioner (there is a recall).
If not - it is the compressor.
Old Jan 1, 2015 | 10:19 AM
khami's Avatar
Found out what it was after I manage to secure a warm environment to investigate (in Buffalo NY).
Apparently one of my zip ties for the vacuum lines snap and the line had just enough slack that it kept hitting the fan. Eventually got caught one the 3 time I tried. Barely enough plastic on the line left by the time I found the issue. Not even sure how it held boost with such small material left. Swapped out the vacuum line and no issue.
Old Jan 2, 2015 | 08:28 AM
Veronica's Avatar
Great! I am glad it is a cheap/easy fix!
Peazoo
Nov 23, 2013 08:07 AM
johnnnyjeans
Jan 1, 2013 10:39 PM
W0459732
Nov 29, 2007 12:25 PM
W0459732
Oct 19, 2007 09:52 PM
