Undercover fastener help
Old Mar 9, 2015 | 05:46 PM
DWILSON357's Avatar
Hows it going guys,
So I may have spun out in an Icerace sunday and tagged up with a snowbank
This ripped out a ton of the pop rivets that hold the splash guard/undercover out.
Is there a standard size pop rivet that will get the job done(i'm assuming they are pop rivets)?
Is there any service manual available online for these? This would probably be the best resource for me.
Thanks guys
Old Mar 9, 2015 | 10:22 PM
neogeo64's Avatar
ebay has bags of them for cheap.
http://www.ebay.com/itm/100Pcs-Push-Type-Fender-Retainer-Bumper-Clips-MR200300-for-Mitsubishi-Honda-/371083056492?pt=Motors_Car_Truck_Parts_Accessories&hash=item566646156c&vxp=mtr
just take one off and measure to be sure they are the same.
Old Mar 10, 2015 | 04:24 AM
DWILSON357's Avatar
I wasn't sure if they were the snap type or if the were the screws with the threaded spring clip
I will go ahead and pull the trigger on these then,
they measure 9mm wide for anybody elses reference, the type you posted would work fine by that measurement, I just don't need quite that many, found a smaller listing.
Thanks
Old Mar 21, 2015 | 06:15 AM
rallidiehl's Avatar
Ah good thank you for posting these! When I looked around my car I found I was missing a few
Old Mar 21, 2015 | 05:14 PM
DWILSON357's Avatar
So I actually just did the rivets today you will need a few 9mm ones
but the undercover uses a majority of the undercover rivets are the same size as the wheel well ones removed when you put on mud flaps which is 8mm(I believe, I will measure them tomorow when I have my calipers)
03Roush2
Jul 28, 2015 07:17 PM
way2qik
Jan 28, 2012 05:56 AM
Phoenix*
Apr 29, 2011 12:24 PM
jberb55
Oct 12, 2009 02:05 PM
