Brake/ABS/ASC Service Needed Lights
Old Aug 4, 2018 | 04:57 PM
frankiejay's Avatar
I've searched the forums and haven't seen this combination yet. The lights come on after the vehicle starts moving (+3mph). At first I thought it was just a wheel speed sensor, I took them to a shop which they checked the sensors with some sort of computer and all the sensors came back good. There are no active faults and the warnings go away with a key cycle. The shop I took it told me it was ECM issues. I will probably take it to the dealer next week.
Here is a video I found on youtube with the issue I have:
Old Oct 7, 2018 | 10:50 AM
frankiejay's Avatar
For reference, I had all the ABS sensors checked with no fault. After driving it for a week, the issue went away (without disconnecting the battery and there were no active fault codes) and it has not come back since then
Old Aug 9, 2019 | 04:24 AM
Cg Rm's Avatar
Fix it ?
Hey did u find out what give you all those lights I'm getting it now
Old Aug 10, 2019 | 08:05 AM
frankiejay's Avatar
No, like I mentioned above it went away on its own. It hasn't come back since then
