Stock turbo ralliart trap speed
So I went to the strip and cant figure why my time is on slow side but trap speed is high. I traped at 107.18 mph but time is 12.915 60ft was a 1.782 any ideas. also I think that speed might be a record on stock turbo
Nice run man. Considering your power (What mods do you have and what dyno did you get your numbers from?), you may be able to pull quicker but so much factors in especially your launch.
My best at the strip is a 13.07 @ 104 mph. It isnt too far off from you but most likely it has to do with elevation and also temperature. Where are you located and your not still in the heat wave are you? lol |
Originally Posted by vicq
(Post 9508784)
So I went to the strip and cant figure why my time is on slow side but trap speed is high I traped at 107.18 mph but time is 12.915 60ft was a 1.782 any ideas also I think that speed might be a record on stock turbo
Originally Posted by Snipingdude
(Post 9508819)
My best at the strip is a 13.07 @ 104 mph. It isnt too far off from you but most likely it has to do with elevation and also temperature. Where are you located and your not still in the heat wave are you? lol But still is that all ur mods in ur sig?!?!?! |
Originally Posted by CFMP RAblue
(Post 9509156)
Nice time{thumbup}
I believe it might have something to with e85 also;) But still is that all ur mods in ur sig?!?!?! But Im at only 90ft above sea level so it helps ;). Im not sure where Arlington Heights is so it may be that as well as E85 like you mentioned. |
Current Mods
UR Down Pipe DC Test pipe DC CBE Custom Intake Made by Devin@ Boostin Performance Grimmspeed EBC 3port 1,000 Deatworks Injectors Waldbro 255 UR upper and lower intercooler piping Ams FMIC Ams Small Battery I Have ran a 12.854 @ 106.88 with a 1.859 60ft Before here is the weather from that run Density Altitude: 1386 feet Relative Density: 96.01 % and last nights run was Density Altitude: 1659 feet Relative Density: 95.24 % so any imput would be great |
thats pretty good for an RA turbo, my best time so far was a 12.7 @108 but i have an x turbo swap done on my car
Ive only been to the track once and my best time was a 13.3 on a weak launch and a 1.96 60' time.
well went to the track tonight!!! and the car went 12.786@106mph on stock turbo with a 1.762 60ft. on stock suspenion and stock wheels and tires not to bad. evox swap soon to be done!!!
(Post 9525666)
does the test pipe really necessary to gain more hp? Why risk voiding the warranty?
Originally Posted by Defcon5Es
(Post 9526875)
