Ignition Switch Wiring
Hola... I have a 04 Ralliart and I was trying to install a PKE push to start alarm system and on the Ignition Wiring instructions it is telling me that one of my ON wires is supposed to be w/o electricity once I have started my car, but this didn't happen.
Both of my ON wires stayed with electricity and when engaging the clutch it produces a grinding noise like the starter keeps running and robbing against the flywheel or something like that. Any advice or idea as to what's happening? |
(we are 2009+ , try posting in the 04-06 lancer forum)
she is right you will get better insight in the correct section.
... but probably wrong wire . most ignitions have one wire that is input(powered wire) and an output wire which has no current until the ignition switch is turned to complete a circuit to power the starter motor. if they both have power now , you most likely mixed them. did you check the wires by holding a voltometer up them when u started the car. if so either the wires are touching or you mixed them up but depends on make , model, year , country |
Thank you for the replies guys. I thought I was posting it in the 04 RA forum.
