Ignition Switch Wiring
Old Feb 14, 2015 | 07:21 PM
ChicoRalliart's Avatar
Hola... I have a 04 Ralliart and I was trying to install a PKE push to start alarm system and on the Ignition Wiring instructions it is telling me that one of my ON wires is supposed to be w/o electricity once I have started my car, but this didn't happen.
Both of my ON wires stayed with electricity and when engaging the clutch it produces a grinding noise like the starter keeps running and robbing against the flywheel or something like that.
Any advice or idea as to what's happening?
Old Feb 18, 2015 | 08:05 AM
Veronica's Avatar
(we are 2009+ , try posting in the 04-06 lancer forum)
Old Feb 20, 2015 | 09:18 PM
Brock077's Avatar
she is right you will get better insight in the correct section.
... but probably wrong wire . most ignitions have one wire that is input(powered wire) and an output wire which has no current until the ignition switch is turned to complete a circuit to power the starter motor. if they both have power now , you most likely mixed them. did you check the wires by holding a voltometer up them when u started the car. if so either the wires are touching or you mixed them up
but depends on make , model, year , country
Old Feb 21, 2015 | 07:37 AM
Thank you for the replies guys. I thought I was posting it in the 04 RA forum.
N33d4sp33d
Jul 20, 2012 03:06 PM
Sn0w Man
Lancer Troubleshooting
Feb 10, 2010 01:48 PM
AlienEvoX
17
Oct 9, 2009 02:17 PM
Nasty Evolution
Jun 28, 2009 11:43 AM
mmartahus
10
Dec 22, 2008 03:06 PM
