225/45-18 Tires
225/45-18 Tires
I've finally decided to replace my stock Advan A10 tires with another brand. I also would like to increase the tire size from 215/45-18 to 225/45-18 at the same time. They'll be mounted on aftermarket 18x7.5 rims.
Does anybody have experience with this size tire? I'm particularly concerned with possible tire rubbing, as the tire will be about 1/2 inch wider. There would be only a little more than 1% difference in circumference, so the speedometer would only be off slightly.
1% on the speedo is nothing to worry about. What offset are your rims? You will only get rubbing issues if you have an aggressive offset and wider tires or if you are lowered and have wider tires/rims you might rub with some offsets. From you worrying about 225's rubbing and almost stock size rims, I assume you have stock like offset +45 to +48. If they are a stock like offset you will be fine.
Did you read this yet? https://www.evolutionm.net/forums/09...s-fitment.html
I just got my 225/45/18 Hankook Ventus V12 on 18x7.5 wheels put on. I'm lowered on RRM springs and have no rubbing issues. It looks close in the rear but the tire will camber in as the suspension compresses. If I get some time later I will post some pictures up.
Continental Extreme Contact DWS tires in a 225x45x18 here put on Enkei Wheels that are 18x7.5. No problems. Pics here https://www.evolutionm.net/forums/09...-black-rg.html
I also have installed the lowering RRM springs and would like to widen the tire width. Are 225s the only size that will fit the stock rims? Or can I go with 235s on stock rims?
I have 225-45-18's on the stock rim and they're fine. Conti DWS's. One point of note, going wider means you can't use the spare tire for very long without throwing ACD service required lights...apparently the smaller diameter makes it think it's constantly spinning slightly more and therefore slipping...
No - Stock rims are 7" Wide - 225 is the widest you would want to go. A minimum of 7.5" is recommended for 235 (8"+ would be ideal)
Price is comparable (225/40/18 to 225/45/18)
http://www.miata.net/garage/tirecalc.html <-- should be a basic tool for anyone shopping different tire sizes. I've used this calculator for over 8 years now.
Compared to stock (215/45/18)
225/40/18 results in: Speedometer reading 2.1% to fast. When speedo reads 60, you're actually going 58.8
225/45/18 results in: Speedometer reading 1.4% to slow. When speedo reads 60, you're actually doing 60.8
225/40/18 are probably a lot cheaper, and that looks to be the most comparable size to the stock tire on the stock wheel.
