How to flush brake fluid?
Old Nov 28, 2011 | 12:13 PM
EyeDreamt's Avatar
I've never done this on any car before, but will be replacing pads and rotors this weekend. Anyone have any guides or tips for me?
Old Nov 28, 2011 | 12:22 PM
TOralliart's Avatar
Get a MityVac so you don't need a second person to pump the brake pedal.
Old Nov 28, 2011 | 01:02 PM
NFSLancerRA's Avatar
The most important thing is to be thorough. A MityVac or bleeder kit from AutoZone is not a bad idea. The key is to make sure that fluid, and fluid alone, is coming out of the caliper before re-tightening the bleeder screw and topping off the system. You should be fine. It is a relatively easy thing to do.
Old Nov 28, 2011 | 01:49 PM
EyeDreamt's Avatar
Ok. I was thinking of switching to ATE Super Blue Fluid. Would I just bleed and bleed until I see blue, or is there a different process for completely flushing the system?
Old Nov 28, 2011 | 01:53 PM
ambystom01's Avatar
Bleed and bleed until you see blue. Be warned, ATE Super Blue seems to stain the lines permanently. Once you've used it, it's really hard to get non-blue fluid again short of going through liters of fluid.
Old Nov 28, 2011 | 02:12 PM
EyeDreamt's Avatar
Good to know. Maybe I'll explore some other fluids. Any suggestions?
Old Nov 28, 2011 | 02:19 PM
I use Valvoline.
Old Nov 28, 2011 | 02:38 PM
sstevojr's Avatar
RBF
I've also heard that alternating the 2 different colored ATE's is an easy way to tell when everything is gone. And work from the farthest line forward (RP, RD, FP, FD IIRC)
Old Nov 28, 2011 | 02:45 PM
jkennedy293's Avatar
Remember to start bleeding at the farthest point from the master cylinder and work your way forward oing to the next closest wheel each time.
Old Nov 28, 2011 | 04:27 PM
^Good point.
Old Nov 28, 2011 | 05:21 PM
RazorLab's Avatar
The Motive Bleeder saved my relationship....
Old Nov 28, 2011 | 05:43 PM
Old Nov 28, 2011 | 07:00 PM
There is nothing like a positive pressure device to smooth things over.
Old Nov 28, 2011 | 07:54 PM
xi's Avatar
xi
Aw man, now you tell me. I just bought a huge can of ATE super blue...
Old Nov 28, 2011 | 07:55 PM
xi's Avatar
xi
http://www.youtube.com/watch?v=MfTml...eature=related
