Replacing only 2 tires
so...i ended up just replacing only the rear 2 tires...when I was at the shop the guy measure the tread depths on the front 2 tires and he said they need to be replaced too....but they had to put in an order for us.....I drove around for ~2 months with 2 brand new tires in the back and 2 worn in the front...ended up getting the ACD system service required light....so I got the front 2 tires replaced 2 days ago, thinking the light will not come on again....but it did today...any idea if the light needs to be reset by the dealer or something?
These things are known for blowing through those pumps, unfortunately. I'm on my second pump right now, and I think it's shot since I've started getting the light again.
man i hope it's not the pump cuz people on this board is saying it's expensive and Mitsubishi won't warranty is under the powertrain warranty (only one guy got it replaced under warranty but he's up in Canada)....what are the chances that the pump failed approx. the same time I replaced 2 of my tires? I wonder if having the mismatched diameter of the tires cuz my differential to work harder and caused the pump to fail...
Zippy452
10
Sep 28, 2015 08:16 PM
johnnnyjeans
Jun 21, 2013 02:48 PM
Boltz.
19
May 28, 2011 06:13 AM
SsZERO
Nov 22, 2007 12:07 PM
brand, evo, evom, flat, front, good, mistsubish, mitsuibishi, ralliart, ralliarti, replace, replacement, replacing, tire, tires
