Rubbing
Old Jul 12, 2012 | 05:10 PM
Luke1bundy4's Avatar
Rubbing
Ok so I got rota g forces, 18x9 +30 with 245/45/18 fenders are rolled and pulled and I'm rubbing on that rear bumper clip that connects to the fender. Anyone know if I could take out the bolt and shave it off? I'm sure there are lots of other screws to hold the bumper on. And I'm lowered on tein s techs if that helps. That clip is shredding my tires!
Old Jul 12, 2012 | 06:26 PM
jRox's Avatar
Remove the bolt. Cut the tab. Drill a hole. Insert zip-tie. Done!
Old Jul 13, 2012 | 01:10 AM
AlphaKennyBody's Avatar
I'm on the same setup and don't rub at all with 1.5-1.6 Neg camber on the Rear. I'm also on NT05 245 which are wider then your normal 245.
I'm pretty sure your A either too low, or your need a better alignment. If your must then yes, you can trim and edit the tab to add more clearance.
Old Jul 13, 2012 | 01:37 AM
bye2u's Avatar
maybe should of went for 245/40 instead of a 45 profile..
Old Jul 13, 2012 | 03:08 AM
Actually yeah I'm on a 245/40/18
Old Jul 13, 2012 | 10:56 AM
Yeah got brand new tires for free though. It's just that clip now, I fixed it and no rubbing!
